Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
The minimum focusing distance
In the Super Macro mode, what is the minimum focusing distance to a subject?
    Master:
  • 852 Answers
Shooting can be performed at a minimum focusing distance of 3cm. An approximate 2.1 cm x 2.8 cm subject can be captured on the monitor.
Posted on Sep 04, 2005
SOURCE:
Im trying to take closeup pics of jewelry, which is the reason I purchased this 12x zoom. I am using the super macro feature but my pics are blurry. Can you give me any tips? Deb
In super macro mode, there is a minimum focussing distance. Any closer, and you have no hope of locking in a focus. So, be sure you don't go past this point.Close up pics have a very shallow "depth of focus" meaning that very little in front or behind what you focussed on will be in focus. Is anything in focus in your pics? If you can exert some manual control over lens openings, you could try using a smaller opening to get more of your subject in focus. When taking close-ups, always use a tripod.
Dec 01, 2010 | FUJIFILM Finepix S1500fd Digital Camera
Can't use macro
Select Macro Mode - this is a fairly obvious first step but I’m always surprised by how many digital camera owners haven’t explored the shooting modes that their camera has. Macro mode is generally symbolized with a little flower and when selected it will tell your camera that you want to focus on a subject closer to your lens than normal (the minimum distance allowed will vary from camera to camera - consult your instruction manual to find yours). Macro mode will also usually tell your camera to choose a large aperture so that your subject is in focus but the background is not.
Read more: http://digital-photography-school.com/macro-photography-tips-for-compact-digital-camera-users#ixzz0KaYY32aZ&C
Jul 07, 2009 | Cameras
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature)
Capable of macro photography, this lens has a 1:2 maximum close-up magnification at the 300 mm focal length. It's the ideal high performance lens for portraits, sports photography, nature photography, and other types of photography that frequently use the telephoto range. It also has a switch for changeover to macro photography at focal lengths between 200mm and 300mm with a maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing distance is 1.5m / 59 in. at all zoom settings.
Dec 25, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
What is the distance at Macro mode?
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD (21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format).(Focal length is 7.2mm. At maximum magnification 283mm x 213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD (13 cm from the lens front) and the magnification is 0.18x (equivalent to 0.7x in 35mm format). (Focal length is 42.7mm to 50.8mm. At maximum magnification 52mm x 39mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD(21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format). (Focal length is7.2mm. At maximum magnification 283mmx213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD(13cm from the lens front )and the magnification is 0.177x (equivalent to 0.7x in 35mm format). (Focal length is42.7mm to 50.8mm. At maximum magnification 50mmx37mm of the subject can be captured.)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Focusing distance in macro mode
On a D-575 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Using the Macro mode, it is possible to zoom through all ranges from telephoto to wide down to a minimum distance of 7.9 inches.
Sep 01, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Accessories lenses
Olympus offers the following add-on lens accessory options: MCON-35 Macro Extension Lens (equivalent to 1/4 life size, subject size that will fill the frame is approximately 1.4" x 1.9" f2.4 Tele/f2.0 Wide, 72mm filter size) minimum focusing distance - 4.75 inches. WCON-08B Wide Extension Lens (equivalent to 28mm f2.0 in 35mm photography, 105mm filter size) minimum focusing distance - 3.6 inches TCON-14B 1.45X Tele Extension Lens (equivalent to 200mm f2.4 in 35mm photography, 86mm filter size-tentative) minimum focusing distance -1 ft. TCON-300S Tele Extension Lens (equivalent to 420mm f2.8 in 35mm photography, 49mm filter size) minimum focusing distance - minimum focusing distance - 3.9 ft.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
67 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
