Question about Acer Aspire L100 PC Desktop
3.3 seems ok
Nick,
I really appreciate your help. Otherwise I'm just stabbing in the dark.
The cap that you originally described (PEC 19) has 3.3 v on the + leg.
The other 2 caps I replaced have 0 volts on the + legs. They are located physically near two 3 pin devices that I take to be voltage regulators (PO13 and PO14)
PO13 has the following designations on the device face - D436 BE6V16
PO14 has D438 BE6118
PO13 has 19.4 volts on the center pin. 0.02 and 0.04 volts on the outer pins
PO14 has 0.2 volts on the center pin 5.09 volts on the left pin (pins pointing down) and 0 volts on the right pin.
Does any of this make sense to you?
Thanks again
Carl
  • 68 Answers
Carl,
does the hard drive spin up? if not it may indicate the fan is on the 5V rail and not the 12V rail.
P013 definately doesn't appear correct and i would guess is the problem component.
Ive tryed googling for the part but not turned up any hits im afraid.
From what I recall the 12V rail needs to be able to source 5A so if you can find a pin compatible device you may be able to replace it as it doesnt look like the original device is easy to find.
You never know you may well find the same device on that old mobo of yours :)
Would be glad to know if you make any further progress.
Regards
Nick
Posted on Aug 25, 2008
I have replaced the low beam bulb 3 times within 2 yrs. on both sides. this is a 2010 Mazda 6
A couple things here. First, did you make sure to not touch the bulb with your fingers when installing. The oils on your hands or any foreign substance on them will dramatically reduce the life of the bulb. If that cannot be the case then I would look for a short in the wiring from you light back to the fuse box. It could be a nick in the wire or a loose connection in your socket causing the short. Just replacing the sockets on both lights could take care of it if you want to just take a stab in the dark. Otherwise find where the short is occurring.
Dec 01, 2016 | Mazda Cars & Trucks
What does the air take hose function
Air Bypass Valve: Honda Projects - YouTube
9k=? 6:00 https://www.youtube.com/watch?v=KCJpBzxKWx4 Jul 7, 2013 - Uploaded by Nick Describing the needs and uses for a Air Bypass Valve. ... Does it really work tho. Read more ... Do Cold Air ...
Cold Air intake + Bypass Valve. ? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid... Oct 19, 2008 - Update: where does the Bypass valve go on the cold air intake? ... you encounter deep water you will know what your maximum allowable ...
cold air bypass valve..does it really worK? - Honda-Tech
honda-tech.com/.../cold-air-bypass-valve-does-really-work-404719/ They do NOT magically separate water from air, if that was what your were thinking ... which cold air intake would u guys recommend? r there any that offer some ...
Dec 28, 2015 | Cars & Trucks
Air intake bypass hose
honda-tech.com/.../cold-air-bypass-valve-does-really-work-404719/ They do NOT magically seperate water from air, if that was what your were thinking ... which cold air intake would u guys recommend? r there any that offer some ...
Head unit assembly of Ionic Breeze model S1830
The caps would seem to me, to be a protection cap,
which would go on to of the spring,to protect from
the electrical current.Hard to say, since I can't see
the setup.See if you can Google a diagram or pdf.
Good luck.
Mar 31, 2010 | Kitchen Appliances - Others
Kenmore/Whirlpool Washer - How to remove console End caps?
its probably the half load button is stuck in the on position inside the switch replace
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Could be.
Ok, they're the kiddies to replace, are they all the same manufacturer? all 1000uf 6v3's?
What happens is the electrolyte breaks down and produces hydrogen gas, sometimes they can literaly explode but more often than not they'll either blow out the top or the rubber plug on the bottom and just leak the electrolyte on the PCB.
The electrolyte is corrosive so best to snip the caps out ASAP and clean the board up with a good PCB cleaning solvent before you attempt to replace.
Sorry if your aware of this, dont mean to teach you to **** eggs ;)
Good luck
Nick Sharp
Aug 21, 2008 | Acer Aspire L100 PC Desktop
19" Widescreen Dark Shading
It is probably a driver issue. see if installing the latest driver fixes the issue. Click here.
Otherwise try running the game in opengl mode(It can run in two modes 1)direct3d and 2)opengl and see if it fixes the issue
Postback if you need more help
Aug 19, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Fujitsu Lifebook C2330 Monitor dark
Your LCD backlight is not working. It is fixable but it is not a repair I would recommend to the typical user. The reason is that you have to disassemble a fairly good portion of the laptop to access the light source and/or the electrical components that control it. If you have excellent attention to detail, patience, experience with the disassembly and handling of electronics and the tools then give it a try. It is also important to also realize that by doing it yourself you risk the real possibility of damaging your laptop beyond economic repair then it may also be worth a try. Otherwise I would strongly suggest you take your laptop to the local authorized repair shop.
Feb 03, 2007 | Fujitsu LifeBook C2330 Notebook
Acer Aspire L100 PC Desktop Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
