Question about Samsung SCX-4100 All-In-One Laser Printer
Printer jam 2 indication
The printer does not print with the jam 2 indication displayed.
  • Anonymous Aug 29, 2008
    Jam 2 message remains after intact 2 sheet paper jam. The printer is no longer available... unfortunateelly I have 2 new toner cartridges.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Please make sure there is no paper left (jammed) in the printer compartment.
Remove the ink cardridge and see if any piece of paper is jammed below or behind the cardridge place.
If there is a cancel button press it several times.
Switch off the printer and let it for a few minutes and then turn it on.
if nothing of the above worked please ask me again
Thank you
Posted on Aug 25, 2008
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: Samsung SCX 4100 Printer
just check the feeder is working normal, and there was no stucked parts on the roller area.
Posted on Aug 26, 2008
taran_2005
  • 10515 Answers
SOURCE: display permanently indicates
Unplug the Printer and Disconnect it from the Power Supply. Then Turn it Back ON, after few minutes say 30 minutes, that would fix the Problem.
If Problem Persists, Check the Machine Once again to make sure that you do not have any Paper Jam.
Refer the Manual to Clear Paper jam, if any. If you do not have the Manual, Revert to me and i would be glad to Offer you the Manual.
In fact, Check Below Link to Clear Paper Jam :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00438945&lc=en&cc=us&product=454816&dlc=en#
Now,
If there is No Paper and still the Message is there, more likely, the sensor has gone bad and needs replacement.
If under Warranty, get it replaced without any Charge unless Hp would charge you more than half the amount to get this Fixed. Still not a Bad idea to call and have a Quote and if the amount is too high, do not shy of asking for exchange in lieu of this. They could Offer you a Nice Discount as Christmas is already here :)
Note - Also Try to remove the Cartridges and again Re-Seated them Properly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 22, 2009
  • 17 Answers
SOURCE: Hp laserjet 4520n: Attention indicator
Look at the feed rollers.
If you pull the paper cassette out and look into the now exposed area, you will see two rollers in the machine, just above where the roller in the front of the paper cassette was positioned.
If these rollers are worn, they will not grab the paper and pull it out of the paper cassette. This will cause the machine to think that there is a paper jam, even though no paper is found in the machine because the machine is looking for the paper via a paper path sensor in the front of the machine, just a few inches up from the paper cassette.
Look closely at these rollers... they should have a "rough" surface. If any of them are smooth, you will have to replace them.
There are two blue hub rollers and one white roller.
Part #'s:
Blue: RM1-0037-000CN (Qty.2)
White: RM1-0036-000CN (Qty.1)
Posted on Oct 26, 2010
  • 193 Answers
SOURCE: My HP Photosmart C6280 printer
visit the following link you will find a solution here.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01257110&cc=us&lc=en&dlc=en&product=3194498&tmp_track_link=ot_search
Posted on Jan 10, 2011
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
Feb 08, 2011 | HP LaserJet P2015dn Printer
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
Machine has an error code & won't print. We have no manual.
If the lamp is on solid that is a cancel job or reset printer indicator
If the lamp is blinking (flashing) that is the secondary Jam error meaning somewhere in the paper path is a jam. The lamp shoul dbe blinking in a sequense - that sequence indicates what are of the printer the jam is. So the lamp should blink a number of times, pause then blink the same number again.
1 blink - jam in feeder sensor
2 blink - jam in manual feed
3 blink - jam under toner
4 blink - jam in output are
5 blink - jam in tray 1
6 blink - jam in tray 2 (if present/option)
Sep 03, 2009 | IBM Infoprint 1412 Laser Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
Sep 08, 2008 | HP LaserJet P2015dn Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
51 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
