Question about Xerox Office Equipment & Supplies
I have an copycentre c2o with open heat error is there anything i can do to fix it
    President:
  • 2,072 Answers
Replace the fuser. There is a weird induction heater in the heat roller that blows . Look up "the parts drop" on google. Call Britt and he will give you as good a price as you will receive anywhere.
Its very very easy to change, takes less than 5 minutes if you have no clue what your doing.
Posted on Aug 25, 2008
  • Rick Kasper Aug 25, 2008
    I looked it up, a new fuser from the parts drop is $160.
Msir machine show error code of 010-327. plese tell me error solu.
The fuser is not warming up properly. Could have paper wrapped around it, but most likely the over heat popped. You will most likely need to replace the fuser.
Jun 03, 2011 | Xerox CopyCentre C128 Black and White...
Open heat error...can I replace on my own?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 13, 2010 | Xerox CopyCentre C20 Black and White...
Open heat error on xerox c20
check the thermistor if is not dirty , then change it
Aug 27, 2010 | Xerox CopyCentre C20 Black and White...
Had a paper jam, cleared jam. Had made probably 30 copies prior to this happening and then the copier doesn't work - open heat error
You probably had an overheating condition that opened the thermostat of the fuser.You'll have to replace the fuser assembly because it is not a resetable thermostat.But before you do that, check the wiring (two smal white wires exitin from the fuser) for an open cirquit or a bad connection to the terminals.
May 27, 2010 | Xerox CopyCentre C20 Black and White...
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
Open heat error
if you meant to write over heat error, it should go away after the fuser cools down. if it continues to happen, the fuser unit will need to be repaired or replaced
Nov 02, 2009 | Xerox CopyCentre C20 Black and White...
What is open heat errot
One of two things, both will require a fuser replacement.
Either the over hear thermostat has open, or and most likely the heating element built into the heat roller has failed. Normally the heating element burns out and displays that message, I have not found that roller assembly spared, and even if you try and swap one from a used fuser to new, they are really dificult to change because of the spring end contacts.
In simple terms, replace the fuser and you will fix the problem.
Mar 28, 2009 | Xerox CopyCentre C20 Black and White...
Open heat
short answer is....no
although you haven't given us much information to go on
Feb 21, 2008 | Xerox CopyCentre C20 Black and White...
124 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
