Question about Kitchen Ranges
Hotpoint oven/range how do i adj temp in oven
  • 63 Answers
Is it a gas or electric if it is gas take knob off usally in front where it says 150 degrees and up and if you look down the shaft you will see a little screw turn it counter clockwise to turn oven down if it is electric take knob off where it says 150 /250/etc... and look behind the knob in your hand it has 2 screws to adjust the oven temp.
Posted on Aug 25, 2008
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
Hotpoint oven won't hold temp and it is not the temp sensor
if it's not the igniter, check for loose wires in the top - my husband tightened one leading to the control board, seems to be working now
Dec 08, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint rgb745bea2ct oven doesnt keep temp. can i ohm it out sensor?
At room temperature the temp sensor should be 1100 ohms plus or minus 50.
Dec 03, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Oven comes up to temp, then doesn't recover
You need to pay me $9.99 to find out how I fixed this.
Jun 24, 2009 | Hotpoint RA620F Electric Kitchen Range
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint oven
Press the function you want - say bake - the set the temperature by pressing the plus sign (+) to increase the temp to that which you desire then press start
Regards
Aug 25, 2008 | Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Mar 09, 2008 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
