Hotpoint RGB745 Gas Kitchen Range Logo
Posted on Aug 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint oven how do i adj the temp in oven??
Anonymous
Level 2:
  • Expert 116 Answers
  • Posted on Sep 05, 2008
Anonymous
Expert
Level 2:
Answers
116
Questions
0
Helped
54898
Points
249
Press the function you want - say bake - the set the temperature by pressing the plus sign (+) to increase the temp to that which you desire then press start
Regards
Hotpoint oven gets too hot
it needs to be calibrated, please get a service tech
Oven burning food
Get an oven thermometer and measure the temperature in the oven to determine if it is at the correct temp or not. If not then there is an oven problem possibly the oven temp probe or the oven electronic controller. If the temp is correct then you are doing something wrong as a cook such as oven temp set too high or cooking for too long.
1helpful
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
1helpful
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Hotpoint oven/range
Is it a gas or electric if it is gas take knob off usally in front where it says 150 degrees and up and if you look down the shaft you will see a little screw turn it counter clockwise to turn oven down if it is electric take knob off where it says 150 /250/etc... and look behind the knob in your hand it has 2 screws to adjust the oven temp.
I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
No water from water dispenser on my ge hotpoint refridgerator
its possible the water tank or tube is frozen up. try turning off the refrigerator and leaving the door open for about 10-15 minutes and see if it will start working again. if that works adj your temp settings to warm the fresh food section up just a little to prevent it from freezing again..
Top Hotpoint Kitchen Ranges Experts
vince
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
