Question about Video Cameras
Blurred image The blurring is not connected to replay on a TV. On using the mode selector, the video recorder works well at times and then when going to use it again, their is no view through the view finder or on the LCD screen. I have tried changing modes, powering down, removing battery, checking recording heads etc, but it is not possible to guarantee an image. Sometimes no image at all, other times, a streaked blur.
  • 2,071 Answers
Samsung's SC-HMX20C is small. Real small when you consider the resolution at which this thing captures at. The unit can fit within one's palm, and while it is a bit heavy, toting it around in a cargo pocket wouldn't be entirely out of the realm of possibility. The device itself felt extremely solid, the flip-out LCD was sturdy, and overall, we were very impressed with how it fit in our hands when shooting. It should be noted that the SDHC / MMC+ card slot is tucked behind the same door as the battery, but it's not like you have to remove the battery to access the card slot. Additionally, the video outputs are hidden behind a small door which is concealed behind the flip-out LCD. Not a problem for us -- just letting the quirks be known.
User Interface
Touchscreen LCD monitors can always be hit or miss, particularly on handheld camcorders. We're pleased to say that the flip-out touch panel on this unit was undoubtedly useful and well implemented. The screen did have a thing for maintaining fingerprints, but it never became more than a minor annoyance. It recognized haphazard touches and only misread our true intentions once or twice during an entire week. Our only real dig here was the slight pause between menu switches; momentary lag was introduced when traversing between a deep menu item and one closer to the top, but it never proved to be anything more than a slight irritation.
The menu system itself was exceptionally well-crafted. A "Quick Menu" button pulled up the six most popular selections (Storage Medium, Resolution, White Balance, Focus, Exposure and Shutter), and at no time did we feel the screen was too cluttered with options. The in-depth menus were yet again well thought out and easy to navigate, making on-the-fly tweaks relatively easy to achieve. Switching between Movie Mode, Photo Mode and Playback Mode was even simpler, as Samsung provided a dedicated button just beside the Photo Capture button solely for swapping between that trio.
We also appreciated the twin record and zoom buttons; users can zoom in / out and stop / start recording by hitting the thumb buttons on the unit itself or by selecting them on the flip-out display. Again, a minor -- albeit thoughtful -- touch. Overall, the SC-HMX20C was designed for the average joe / jane to pick up and fire up without ever having to tear into the user's manual. Sure enough, the only time we ever referenced said pamphlet was just to make sure we didn't miss anything while surfing around the UI ourselves. Granted, this also speaks volumes about its intended audience. Yeah, it does 1080/30p and 1080/60i (along with 480/60p and an SD-only SlowMotion mode), but this camcorder isn't made for professionals. That being said, folks obsessed with archiving every single family outing in stunning HD will find plenty to love.
Gallery: Samsung's SC-HMX20C 1080p camcorder hands-on
Video performance
Okay, so the UI is remarkable, but how's about the actual performance? First off, we were quite amazed to find that the 8GB of internal storage space could hold around 71 minutes of 1080/30p or 1080/60i in Super Fine mode. Knock those resolutions down a bit (but c'mon, who is going to do that?), and you can fetch upwards of 2 hours without even slapping your own SDHC card in there. A fully charged battery showed about 90 minutes of life, and even with heavy LCD use, it proved quite accurate.
Capturing video was a cinch, and we really appreciated how the camcorder kept track of files internally. Upon connecting it to Windows XP and OS X-based machines, it simply mounted as a drive and enabled us to pull the (very manageable / playable) MPEG-4 clips over to our computer's hard drive. Simple as that. Be forewarned though -- playing back said clips via QuickTime requires a pretty potent computer. Otherwise, Full HD clips will skip and stutter as your rig attempts to churn through.
Overall, we'd have to say we're pretty pleased with the unit's ability to log clips. Yeah, we wish that totally novel SlowMotion mode was available in HD, and we wish the low light performance was a touch better (as with every other camcorder out there), but we really can't find too much to kvetch about. While shooting in broad daylight, we were satisfied with results when keeping in mind that the target audience is novice / amateur users. Clips were free from excessive grain, the audio capture was sufficient and playback on both a computer and an HDTV was up to par. The 10x zoom was decidedly smooth and snappy, as well.
While shooting in low light, the expected grain monster reared its ugly head, but such is the case with all small, handheld camcorders to be frank. In other words, we wouldn't recommend this unit for those who find themselves using it primarily at night or in dimly lit scenarios, but those who wander outside every now and then during the day (imagine that!) will probably be pleased with what it can do. One other note on the SlowMotion: it's a sweet feature, and it sure adds some wow-factor, but the inability for it to function in HD is a real bummer for us.
Photo performance
Alright, we get that you aren't seeking out a camcorder for its still shot abilities, but hey, Sammy included it, so we tested it. Put simply, the image capture mode isn't half bad, and it's actually passable in daylight. Don't get it twisted, however -- we'd still strongly recommend carrying your trusty P&S / DSLR around and using that when possible, but if you're trying to do everything yourself and just can't find time to fish out that shooter, the SC-HMX20C should suffice. Of course, we're comparing its results to other camcorder results that we've seen in the past, and from that, we came away reasonably happy with what it could do.
Posted on Aug 26, 2008
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Jan 13, 2014 | Sanyo Xacti Cameras
Blurred image
OK, when you say quality is poor, how are you judging this quality ?
EG, are you hooking it up to a decent TV and watching it back, or are you pulling it to your PC via firewire and watching it there ?
If via firewire on a PC, you may be experiencing interlacing issues which make it look worse.
In low light conditions I know the stuff I take looks a lot worse, it may just be that. Just step outside and take a quick clip as a comparison.
Hope this may help;
Aug 25, 2008 | Samsung Video Cameras
When recording dmr-ex768 on hdd or dvd disc moving fast images become blurred not focused.Not a signal problem all channels and sky tv are clear when watching.
If you set the record resolution to a highr grade, that will help. It is a case of size on dvd disc and time left to record, versus quality of recorded images.
Jan 18, 2011 | Televison & Video
Viewfinder shows blurred images
First, rotate the mode selector dial to "Auto", then check to ensure that you're not in macro mode. Also make sure that your lens is clean and there are no smudge marks.
If you've done all the above, and you're still getting blurred images, this then might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot A80 Digital Camera
Optic viewer blurred image
Not much that you can do with that, try adjusting the small focus lever on the underside of the viewfinder, as this might fix the blurred image, your lucky that you didn't, break something on the camera.
Jan 05, 2008 | Sony Handycam CCD-TRV37 Camcorder
Samsung Blurred Camcorder Screen
the lcd screen is filled with straight colourfull lines
can't see any image on it
Sep 23, 2007 | Video Cameras
Out of focus/flashing code
that problem is on the lens the two motor is not working properly...sometimes it is a poor connection to the socket of the main board...other is photo sensor of the lens(not the ccd image sensor)or the driver ic of the 2 motor...i suggest you have to go the service center for repairing you camera cause it need to disassemble the camera for doing this....
Aug 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Blurred picture
You may have macro mode on> Just a suggestion?
Aug 24, 2006 | Canon PowerShot A85 Digital Camera
Camcorder will record but no image...
Its a stuck iris assy an iris cucuit fault or many small pana cpsm that go bad all the time in these unit. Mke sure the iris didnt het seitched to manual andif it is i auto try tappin the lens a littlethe see if it opens Good luck
Apr 16, 2006 | Quasar VM-L152 Camcorder
Video Cameras Logo
344 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
