Sp3 help how do i do what you said to do, load a boot disk? sorry i turn the comp on and use it thats about it can i do this is safe mode cus that is the only way my comp starts up
    Scholar:
  • 65 Answers
You need a boot disk on a 3.5 floppy disk. load this disk, then start the pc. it should start in ms-dos. at the prompt=type "format c:" it will ask a series of questions, answer to proceed. i.e. y/n to format your drive. know that you will loose everything already on your hard drive. then using the recovery disk. start the pc and continue to recover.
if you don't have a floppy or a boot disk i can possibly assist with these as well -just let me know
hope this helps
Posted on Aug 25, 2008
  • matthew carroll
    matthew carroll Aug 25, 2008
    p.s. any windows 98 - ME - or other boot disk should do. as long as it loads msdos.
Black screen
on booting press the f8 key then select the last known good configuration, check it
Feb 05, 2013 | eMachines T3616 Desktop PC
My comp says i need to turn off safe mode its preventing certain things from loading
Hi, open your computer in safe mode and uninstall some newly install software. Otherwise--
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Computers & Internet
After installing xp sp3, opening it can't pass windows. How can I fix it? I completely installed xp sp3 os in my unit. The problem comes when I it re start, when it reaches windows it stopped,...
Maybe its a Bad Update. try to Boot to Safemode first and Uninstall the Installed Service Pack 3
To get into the Windows XP Safe mode, as the computer is booting tap "F8 Key" Continuously which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Then, uninstall Service Pack 3 Start>Control Panel>Add or Remove Programs then look for Service Pack 3 and Uninstall.
If it did not work try Using System restore.
Start>All Programs>Accessories>System Tools>System Restore.
Hope This Helps
May 10, 2011 | Computers & Internet
I have a compaq v 2000 and when i turn on the comp safe start menu comes on then when i type enter for start windows normally a blue screen shows up and the computer cuts out or turns off automatically...
Unplug all additional devices, printers, external drives, network cards, etc. If it won't boot into safe mode, you will need a windows disk. Load the windows disk, and if it's Vista or 7, get the advanced repair options, and do a system restore. If it's XP, just do the computer repair. Windows vista also has a startup repair you can run from the Windows disk. We need to know the operating system to help you
Jun 13, 2010 | Computers & Internet
Windows xp boots but the desktop will not come up
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 01, 2010 | Computers & Internet
Unable to load desktop ASUS 1005HA XP SP3
Hi
It seems you are stuck in a windows loading loop
Please do the following
1) Go into safe mode (swith the pc on and keep pressing F8 repeatedly until you have a menu presented to you, from the menu choose safe mode)
2) Once loaded click on Start>Programs>Accessories> System Tools> System restore
And restore your computer back to a point before the update was done
if it still loops when using safe mode through the method shown above then unfortunaltey you will have to reformat the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Automatic updates just loaded windows xp home sp3. now system will not boot it just keeps cycling blue screen
Try to get into SAFE MODE by hitting F8 as it boots.
There may be a driver that is incompatible with SP3.
If you can get to SAFE MODE, try doing a system restore to a previous restore point.
I personally hate automatic updates that are out of my control.
Also read this: http://support.microsoft.com/kb/950717
AND this one, while an HP machine, yours might be similar:
http://www.fiercecio.com/story/hp-working-fix-windows-xp-sp3-problems/2008-05-16
Jan 19, 2010 | Toshiba Satellite M35X-S161 Notebook
HP a1620n- Will not startup properly
try starting in safe mode then when it windows starts/full loads shutdown the computer. Then restart the computer-it should start normally.
Dec 01, 2008 | Computers & Internet
I can't boot in safe mode
Why do u want to boot in safe mode. Is your winxp corrupted?
May 27, 2008 | Toshiba Satellite A135-S4527 Notebook
Acer L100 comp wont start past the windows loading screen
If I were you I would reformat your PC. In short words reformatting you Delete everything from the pc, the reinstall the OS(Operating System). Once the process is done, your PC is alot faster, and fresh. What happens to most people's PC it gets bogged down, and you go along time without cleaning it it will crash, just like a car.
There are hidden folders within the OS such as the prefetch where files are kept to help you boot problems faster, but the prefetch gets bigger each day, and isn't really needed.
To clean the prefetch you would go to Start>Run>type "prefetch" without quotes, once it opens the folder delete ALL files in it, a shortcut is to click any fil inside the prefetch, and press "ctrl+A" that will select all the files and now simply press Delete, and confirm Yes.
Something else to help maximize your system is to do a "disk clean up" access that by going to start>all programs>accessories>system tools
I hope this helped you maintain a better system in the future, if I were you I would go ahead and do the reformat then use the tips I just gave you to keep your system in shape.
Also another top make sure you keep your system clean of threats,(malware,spyware,adware,etc...) I would recommend Norton or Mcfee, I go with www.grisoft.com and www.eset.com, another one I like is www.trendmicro.com its up to you which you choose.
Good Luck!
Oct 15, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
