Question about HP LaserJet 3200se Printer
Hp lasetjet 3200se
I just started working at a school this morning. They unplug the fax machine for the summer as no one is in the office. I came in and plugged it in. Have waited all day for a fax the machine does not receive or send. It is hooked up correctly as far as I know. Any ideas?? School starts tomorrow and am waiting for records
  • 24 Answers
Make sure the phone line from the wall is plugged into the correct socket on the rear.
There are 2 plugs one to connect to the phone and the other to connect to the wall.
Posted on Nov 06, 2008
My HP laserjet 3200 has receiving faxes turned off, how do I turn it on to receive faxes??
I suggest You Go to Official HP Printer Page For You HP Printer Problem On Below HP forum URL Link: Cannot Send or Receive Faxes
Feb 26, 2014 | HP LaserJet 3200se Printer
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
HP Laser Jet 3200se fax machine
Hi..
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
4. When display reads PERMANENT STORAGE INITIALIZE or HP LASERJET 3200
release the buttons.
Jan 09, 2009 | HP LaserJet 3200se Printer
HP LaserJet 3200se 79 service error 694:SM.C
1st shut the printer off
2nd Disconnect it from the Computer
3rd turn it on
Does the error still occur?
If it starts properly print a configuration page.
If this is possible you have a Printer Driver issue.
Replace the Print Driver.
If it still has the error when the printer is NOT connected to the Computer then you have a firmware issue most likely.
Nov 06, 2008 | HP LaserJet 3200se Printer
I have changed from a 2 line phone system to a 1 line. I am still using the same 2 line wireless telephone/answering machine. The telephone will only work for outgoing calls and not for incoming. The HP...
I just bought a used hp 3200se and am trying to use it as a stand alone fax. It (so far) does not answer incoming calls. I found that I can manually answer a fax call and then the machine seems to work fine.
I tried connecting to ...oh, by the way, I have digital phone service from Comcast, an analog line and it seems to work fine. So maybe the 6310xi is the same or maybe there are setting to deal with a digital line. Maybe something in this will help.
John Mavis
Nov 03, 2008 | HP Office Equipment & Supplies
Comm errors
The fax machine needs to be reset. Simply shut off the machine, wait one minute, and turn on machine & fax. If turning off the machine does not clear your machine then you have to unplug the machine & follow the same procedures. Worked for me.
Prosperity Office Worker
May 06, 2008 | HP LaserJet 3015 All-In-One Printer
CANCELLING INCOMING FAXES
Unplug the phone line and unplug the fax machine. Then clear the memory if it starts printing out again.
Mar 07, 2008 | Brother IntelliFAX 4100 Laser Fax
HP Laserjet 3200 Fax Machine
At a guess! Switch off- disconnect from the wall socket leave over night If that does not work - Get onto HP Technical Support
May 26, 2007 | HP LaserJet 3200se Printer
BEEP, BEEP,BEEP
The Start Button can become stuck on these very easily. If it is stuck, then press it down and it should jump back.
Jan 31, 2007 | Brother IntelliFax-2820 Laser Fax
HP LaserJet 3200se Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
