Question about Zanussi Washing Machines
I have a zanussi jetsystem washing machine which has stopped mid cycle and the error code it's displaying is 2h. What does this mean please? Thanks, Elaine Patchett
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Posted on Aug 26, 2008
What does e90 mean?
  • E90 Error - YouTube
    • 3 MIN
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Machine stopped mid cycle and green light flashing under green start button
    Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
    Hotpoint, Indesit, Zanussi error codes
    Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
    If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
    No Option lights?
    With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
    This information is vital, and needs mentioning when reporting a fault.
    Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
    Zanussi jetsystem 1400- error e90
    e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
    Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
    Hope this helps.
    May 19, 2010 | Zanussi FJS1225W Front Load Washer
    Error code 40
    call AAA washing machine doctor on 0863949848 or visit
    Mar 02, 2010 | Washing Machines
    Error E20
    zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
    Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
    Error code E20 comes on during a wash cycle. i
    If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
    Oct 18, 2009 | Washing Machines
    hi there e40 fault could either be your door interlock or main pcb
    Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    170 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
