Did you press the mute button again, some TVs use this method.
Yes. I guess I should have mentioned that I tried that as well.
You will probably have to go to the system setup from the menu and check the sound application.
So I went into the settings and restored everything to default. Took about 20 minutes. STILL no sound. What the ****?
Quick ?? does the sound on system setup have ext speakers on or internal speakers?? Does the remote light up when you press the mute button?? Is the mute msg. still on the TV ??? Do you have ext speakers you could plug into the TV and put the sound to ext speakers ????
Did you check the remote to make sure the mute button wasn't stuck partially depressed?
Yup! I just checked both remotes. Neither is stuck.
