Question about Samsung NeXus 25 MP3 Player
Blank screen my radio powers up but the screen is blank. I took the battery out and also tried to reset on the power button....no screen still,anyone else having this issue???
  • rikkimc Sep 16, 2008
    I have the same problem. I think the LED (or LCD- not sure which is which) is broken from me dropping it so much. I have been looking on-line all morning for a solution and am hoping I can get it repaired someplace so I don't lose all of my playlists. Have you figured it out?
  • jockobock Nov 01, 2008
    I have a broken LCD screen on my Nexus25. Where can I get a replacement screen?
This has happened to my radio several times after I've dropped it. This is how I fixed the problem:
1) Take the radio out of the cradle and let it play until the battery runs low and
the radio can no longer play.
2) Put the radio back into the cradle, plug in the power cord. When it comes on
the screen should no longer be blank.
Posted on Apr 14, 2009
Why when I turn on my zeepad screen is blank battery is fully charged the green man shows then blank screen?
Hi, try a Hard Reset!
Normally, you have to hold one of the volume buttons down while powering on the device(try them one at a time). If you get a screen that says something about download, try the other volume button.
Once the device has booted to the "special recovery" menu, this is controlled by one of the volume buttons to scroll through the options and the POWER button acts as an enter key. Be on the lookout for an option that says something about "restore factory settings" and select that!
Oct 18, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
Treo 700w-Blank screen
You may have a faulty screen
Have you tried a HARD RESET?
Perform the following steps:
Pull the battery out. Put the battery back in while holding the RED button down and a reset screen will appear.
Push the up button on the five-way to start the reset process.
Alternate process:
Similar to the hard-reset of the Treo 650. Remove the battery cover.
Press and hold the Red radio button.
Use the stylus to depress the reset button next to the battery.
Push the up button on the five-way when you get a prompt to "Erase all data".
Replacement screens are available on ebay.
Sep 04, 2008 | Palm Treo 700w Smartphone
LCD screen is blank in normal picture mode. I
This Camera has an CCD issue. It seems that the CCD of the Camera is gone bad. However, you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
Jan 09, 2009 | Computers & Internet
Blank white screen sony DSC t77
To Power Reset the Camera, please remove the Battery from the Camera, press and hold the Power button for 30 seconds and then reinsert the Battery.
Another option: I took the battery out and I pressed Menu and Shutter button for 30 seconds and it worked! The screen is back!
Jan 05, 2009 | Sony DSC-T7 Digital Camera
Froze
if there is a reset button on the back of ur nwz device bottom left on mine, poke the whole with a pin to reset, i should still have ur songs etc
Feb 23, 2008 | Audio Players & Recorders
LCD display has gradually disappeared, now I have nothing. I have had this problem with other sangean products. Is there something that can be repaired? If so where can I send it for repair? Please...
This is a defect in the radio. Reportedly this issue was resolved in later vamps of production, but it still seemed to persist. We discontinued this model due to this exact reason. At this time there is no other solution and the factory can not tell us what the problem was and simply pointed to the LCD.
Feb 20, 2008 | Sangean PRD2 AM/FM/TV Radio
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
YB 300 PE
The reset button didn't work for me.
Mar 03, 2007 | Grundig YB 300PE AM/FM/SW Radio
Unit Powers on but Screen is not working.
I had the same problem before. I thought the mechanic broke my radio. The power button will not work on the radio, right? I couldn't turn it on or off, but the blue lights stayed on all the time. What I found out is that I had to put a new battery in my remote because it died at the exact same time. Crazy, huh? But anyways, you have to use the power button on the remote or else it will stay black forever. Once you turn the unit on with the remote, it will prompt you to enter your password. Like guest said before, if you didn't set your password before, then the default code is 0000. I hope you get that thing working!! -kev
Sep 24, 2006 | Panasonic CQ-VD7001U Car DVD Player
Samsung NeXus 25 MP3 Player Logo
182 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
