Question about Epson Stylus CX6400 All-In-One InkJet Printer
My epson dx6400 printer
When I turn it on the error light comes on it has only just started to do it having worked perfectly for years. It makes a strange noise and I wondered if anything could be jammed, perhaps you could help.
Thanks Sue Woolcott
  • 1 more comment
  • Chicos Aug 26, 2008
    Yup, mine just started with the same problem today as well...it's worked great for years. Screeching sound. I opened up the top and turned it on, seems like the "pully" is spinning but not grabbing the print heads. This printer has been great so this is really a bummer.
  • GrandmaTee Sep 07, 2008
    When I turn on my cx 6400 I get a grinding sound and the error light and message come on saying to check my documentation and call the technician. I tried to remove the ink cartridges so I could check for anything loose but couldn't get it to budge. I even turned the printer upside down shake anything out that might have inadvertently fallen in. Nothing! I turned it off and let it rest for about 15 minutes then turned it back on. Same thing. I really don't want to have to buy a new printer I just put out over $150 for new ink cartridges.
    Problem Solver:
  • 14 Answers
Mine had a tiny piece of the carriage that holds the ink snap off. A little squiggly part. They said it was repairable, $57 for the part, $65 or more for the repair, and $70 to ship back and forth!  SAD ME!  I must buy a new one!  Anyone want to buy a bunch of cartridges cheap????
I wonder if there is any way to by-pass the printer and use just the scanner or just the camera cartridge reader??
What a waste!!!
Candy
Posted on Sep 08, 2008
My Epson Perfection 1660 scanner is stuck. The
you want to go into the error count menu on the printer and reset after you have corected whatever caused the malfunction
May 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX3900 won't turn on
Do you used ORIGINAL epson cartridges? I used false ones, the yellow one exploded (I'm NOT kidding) inside the printer, and it died. Too, may cause errors on the printer's motherboard, on each cartridge, have a chip who don't metter the ink inside, calculate an extimated value. When you put a false cartridge, the chip may send wrong/corrupted data to the printer system, making it dizzy, and stop working... Epson products have short lifetime, i rarely saw an epson printer go more than 6 years, the most ones die on the first year. Is what i know, good luck.
Jul 04, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Printer displays message "Printer error..." and error light is on
Turn off your printer. Then disconnect it from your computer. Open up the whole scanner unit to check if there are obstructions blocking the way of the printhead or if there are obstructions down the paper feed area. Press the part of the cartridge cover that is showing to make sure that it is closed properly. Reload the papers. Turn the printer back on. Unfortunately, there is no software reset for the error. Please log on to epson.com to find a local servicer near to your area if your unit is over a year old already. Click on drivers and support then click on help me find a service center.
Apr 29, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Don't print error scaner
have just managed to repair my Epson CX3200 thanks to the site! It took 24 hours of messing about but now it works perfectly again. It had the error light on and the display said certain items inside printer are beyond user life contact distributor. It has been a great machine for 3 years exactly and as it had been performing perfectly I was loathe to bin it. I followed the advice and hey presto! I have few tips to anyone attempting same.
1. Download from the site as recommended SSC Service Utility http://inkjetprinterhelp.us/
2. When taking off the scanner unit there is a smallish cover on the left hand side of the printer at the back; remove this and disconnect two ribbon cables, two cables with push pin conectors and a spade connector, 5 altogether.
3. Two screws hold down the hinges of the scanner unit remove and store carefully. Lift off scanner unit.
4. Take out four screws holing printer body on, long magnetic philips screwdriver needed. store screws lift off cover.
5. At back of printer are the three waste ink pads; use a spade end screw driver to lift out one at a time. They are about 5cm x 9cm and the bottom one is slightly different shape to other two.
6. Rinse them thoroughly with water and then squeeze out and dry. I used kitchen roll and then hair dryer.
7. Replace one at a time tucking in corner bits with screwdriver.
8. Replace body, scanner unit, wires and cover.
9. Connect up printer and switch on. Error light will come on again; don't dispair, this is what fooled me. Open SSC utility on desktop and then close; icon appears in lower right screen on application bar like printer icon. Right click and pop up menu appears; left click on "Protection Counter" and then "Reset Protection Counter".
10. Turn off printer and then switch back on again. Error light should go out and you can carry on.
Apr 17, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Photo Stylus 950 not functioning
when ever you want to refill ink make sure, that the ink you refill decompressed for about 30min before you fix it into the printer.
Another thing is that you uninstall the software of the printer and reinstall again, and check the power supply of the printer is working perfectly.
Dec 03, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Problem after jam paper
Turn off printer
-check for specks of paper inside the printer or parts that may appear to be damage.
-turn printer on
If you'll get the same error lights chances are there is an internal error. Sensor mechanism might be damage.
Check this site: www.epson.com/loyalty and use the passcode: Lock then register.
Thanks for your time, hope this will help.
Apr 05, 2008 | Epson Stylus C86 InkJet Printer
Epson 1520
If all the lights are flashing on your printer when you power it on, that means an internal error has occured.
Feb 19, 2008 | Epson Stylus 1520 InkJet Color Printer
Epson Stylus Photo R220 InkJet Problem
i have a R220 it says it needs a service can you help
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
432 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
