Question about LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs
Leaky washing machine
We bought our washer in 2006 at Home Depot. I noticed water on the floor more than a few times. I made sure door was closed properly, gasket clean, hoses good from the house and to machine, exit hose fine - no blockage. It was ok for a while then I checked it the other day and suds were coming out all over the floor - and I did not think I was using too much detergent. The machine had 4 minutes left of final spin. I pulled the machine out to find suds-water coming out of safety air vent. That night we again did all the checks- hoses, gasket, cleaned out the drain pump filter, inspected the screens in the hoses and made sure machine was level-also decided to use even less detergent. Everything good for about 10-15 loads until today noticed water on floor again coming from the safety air vent. I make sure my loads are not that big and adjust spins to bulk of loads. There have been no warning messages on the machine. What could be the problem? I would appreciate your help.
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Ge dish washer just installed. First run. All lights working but cycle will not start. Error beeps indicate door not closed but it is.
That is exactly what the problem is. There is a switch on the door latch, it is not showing the door is latched. Could be bad switch, loose hardware or not connected,
Jul 08, 2017 | GE GDF570SGFBB Fully Console Dishwasher...
Water collecting in wash drum when not operating
You are correct. One of the solenoids on the water valve is not shutting completely and will need to be replaced before it sticks wide open and cause a flood. Here is the part to order. To replace the valve, remove the screws on the top panel, slide it back and lift it off. There you will have access to the valve replacement.
Nov 05, 2012 | Electrolux EIFLW55HIW Front Load Washer...
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore front loading washer. I normally leave the front door open when not in use. I came home the other night to water dripping from my dining room ceiling (Washing machine is on second floor...
The water solenoid could be defective. A solenoid is an electrical switch that pulls a shaft out of the water line to let the water flow in. The timer controls this along with water level sensors. That solenoid is a big electric magnet that operates when the power is applied to the electric coil and it snaps the shaft out of the water line allowing water to flow. It also compresses a spring around the shaft and when the power is removed from the coil, the spring snaps the shaft(valve) back into the seat of the water line. If the spring is weak or broken or blocked by debris from hard water, it does not close all the way and allows water to leak. Very similar to a leaky faucet.i expect that the solenoid will have to be replaced.
Jan 11, 2011 | Kenmore Elite 45986 Front Load Washer
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Water accumulates inside the washer
i guess you have washer drain pipe plumbed into a spigot on the sink trap. if so, when you empty sink, some of the water goes down the washer drain pipe and ends up filling your machine.
to cure, take the drain pipe as high up as possible under the sink in a swan neck and that should cure it. its a common problem
Jul 22, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
LG WM2077CW XL Front Load Stackable Washer with 7 Washing Programs Logo
203 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
