Question about Acer PD120D Multimedia Projector
Won't power up at all
My church has an Acer pd120d projector with at most, 500 hours on the bulb. It won't power on at all, no lights, no fan activity, nothing. Acts like it isn't even plugged in. If the bulb is shot would it act this way or would there at least be some indicator lights operating?
  • pogyfarm Jan 23, 2009
    Its a DLP projector, lamp is mercury gas, no filament. No mention of fuses anywhere in the owners manual.
  • Acer Master
  • 5,568 Answers
There is a chance that it is fuse protected inside.
When a filament-equipped lamp fails, it can create a momentary surge; you've probably seen this when a standard tungsten bulb flashes very bright in the process of dying completely.
If you no longer have the User Guide, you can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD120-_E
It may contain information about any fuse it uses.
Posted on Aug 25, 2008
A flashing red light came on my acer projector pd120d but it did not stay on it displayed the power, temp and lamp
Projector bulbs generate alot of heat. Make sure the vents are not blocked or dirty. Check the fan to make sure it is operating properly. Hope this helps.
Jan 06, 2014 | Acer PD120D Multimedia Projector
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
After bulb burns out during church service and fan is running when power is turned off and bulb is replaced. Projector will not power back up.
Hi, I would suggest that you give it more time to cool down in the future, that is why bulb burned.
There could be more heat damage to projector. Check for reset botton and push carefully. listen for click. Look at main switch with more detail (worn out) Bring to be repaired. Good luck.
Jun 13, 2011 | InFocus DP8200X R Refurbished LCD...
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
Projector keeps shutting off and red light comes on
We had a projector at our church that was hooked up to a light switch to turn it on or off and it kept burning the bulbs out. We had an expert come in and look over our situation and he said When you are finished with the projector let the fan keep blowing until the unit cools down. Ours had a switch for the bulb as well as one for the fan. We turned out the bulb and left the fan on for an extra ten to fifteen minutes. That let the bulb cool down gradually If you just cut the power the bulb over heats and will burn out. Yes turning on for a few minutes will burn it our quicker as well. Hope this helps.
Mar 14, 2017 | Dell Projector Lamp for 2400MP
Acer pd726w projector beeps
I hate to echo this problem, but did either of you ever find the solution to beep code? Our church has had the projector for just two years and the lamp must have only about 400 hours on it.
Oct 20, 2008 | Office Equipment & Supplies
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
Shrinking Screen Display
It can be a problem with teh bulb...you may want to make sure that the fan is not shutting down when you power off the projector becsue that may shorten the life of the bulb,...the fan should remain on for a while to continue cooling off the bulb....it probably won't hurt to have use another fan pointing to the projector while in use...
Apr 30, 2007 | ViewSonic PJ458D Multimedia Projector
Acer PD120D Multimedia Projector Logo
772 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
