Question about Frigidaire FMV156DC Microwave Oven
Smoking microwave I used my microwave in the morning and it's ok; then I cooked at lunch time and used the fan, after that when I used the microwave it started to released some smoke in the front vent and it smells like a burned rubber. What's wrong with my microwave? or is it the fan?
  • Frigidaire Master
  • 9,098 Answers
It could be the fan motor, a component on the circuit board that drives the fan (triac) , the magnetron, high voltage transformer, etc.
It will need to be diagnosed. Smoke is always a bad sign, but not necessarily expensive for a do-it-yourselfer.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 02, 2008
Noisy microwave on first Start... Not noisy on subsequent Starts
Does it sound like a fan blade rubbing?
Can you make a short video and upload it or share with me directly?
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 18, 2017 | GE Microwave Ovens
Exterior of oven , top and both sides gets very hot to touch, when cooking +- 10 minutes or more the last couple of days; no Error ( E41/42/45 or 47 are being displayed. Fan is normal, functions: OK
There could be food or oil buildup around the door frame which will absorb some of the radiant and microwave energy whilst cooking. Give it all a good clean and see if that helps. If everything else is working properly, it may be a problem with the cooling fan. Microwave ovens have a "stirrer fan" inside the roof or rear of the cooking area to disperse the microwaves and some convection / microwave ovens also have a cooling fan which assists in dissipating heat within the cabinet.
Jan 04, 2016 | Microwave Ovens
Worked perfectly today for lunch and now won't cook anything....all looks like it's working all controls work, clock etc but no cooking
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Will an over the range microwave exhaust fan start automatically If the range cook top gets too hot.
NOT THAT I'M AWARE OF . YOUR UNIT SHOULD HAVE A SWITCH TO TURN ON AND MUST BE TURNED ON MANUALLY
Oct 12, 2009 | KitchenAid KHHS179L Convection/Microwave...
My fan works on my microwave by it does not draw suction
Actually, the fan in the microwave is only there to cool down the magnetron which cooks the food. It gets very hot over a period of time and the maintains constant temperature across it. Suggest you use an extractor to remove fumes.
Sep 27, 2009 | GE Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
1,189 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
