SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
SOURCE: users manual for OLD kenmore sewing machine(158
I need the instruction manual for a Kenmore sewing machine 158.19141
SOURCE: Sears Kenmore Model # 5186 Problem with stitch length
I had same problem. Took the dial off and turned by hand.
