Samsung SCX 4100 Printer
Printer jam 2 indication on the printer display
Rebooting the computer and printer did not correct the problem.
Please let me know where the jam 2 sensor is located.
  • rossw602 Aug 25, 2008
    I need to know where the [jam 2] sensor is locater so I can fix the problem.
    Brigadier General:
  • 3,614 Answers
Just check the feeder is working normal, and there was no stucked parts on the roller area.
Posted on Aug 26, 2008
Just brought my SCX 4100 into use in my office, worked perfectly at home on a Windows XP system but in the office on a vista system the printer works fine, the copy function within smart thru 4 functions...
Did you install the correct driver including the scan driver? The drivers are available at the Samsung Site: . Click on the Driver tab for most or the Software Tab for the SmarThru4 program. Make sure to get the correct version for the OS on the office computer. Generic OS drivers often only run the printe, not the scanner. Uninstall the generic driver before attempting to nstall the Samsung driver.
Next check the data cable. Scanners require bi-directional communication with the computer and can fail when the printer works.
I hope this helps.
Jan 24, 2011 | Samsung SCX-4100 All-In-One Laser Printer
Samsung scx-4100 priner doesn`t go past warm up please wait
Hi danie_van_vu
You can download the manual from Samsung support website which i have at the link here
You could try uninstalling the software then reinstall or make sure Samsung scx-4100 printer is selected as your default printer..Hope this helps cheers nikki
Please rate the answer. Thanks for using FixYa.
Jan 15, 2011 | Samsung SCX-4100 All-In-One Laser Printer
The display says there is a paper jam, but there is none
Sounds like the printer need to be "reset"
Cancel all print jobs.
Disconnect the printer from your computer
Turn power to printer off and unplug it.
wait 1 min, then reconnect printer to your computer.
then plug printer back in and turn it on.
Start your print job over.
Should the paper jam suppossedly still exist, cancel the print job and run the maitenance program off the printers' menu that is stored on your computer.
Start print job again.
Should the problem still exist contact support at Samsung via the links on their homepage.
Good luck.
Oct 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 Jam 1 or no Cart
Put cartridge inside correctly and press lower inside again.
if not solved
there are loose catridge connection, check or replace cartridge (the connection at right side in the cartridge)
Feb 26, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Software cd missing
Here's the link for you:
Just choose the driver for your operating system and you should be printing in no time. :)
Dec 12, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Please make sure there is no paper left (jammed) in the printer compartment.
Remove the ink cardridge and see if any piece of paper is jammed below or behind the cardridge place.
If there is a cancel button press it several times.
Switch off the printer and let it for a few minutes and then turn it on.
if nothing of the above worked please ask me again
Thank you
Aug 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Printing prob while adding printer on sharing basis
I have a SAMSUNG SCX-4100 Printer which is not working even though printer is installed to the system the message is appears as " WINDOWS CANNT CONNECT TO PRINTER, THE LOCAL PRINT SPOOLER SERVICE IS NOT RUNNING. PLEASE RESTART THE SPOOLER OR RESTART THE MACHIN. Please suggest in this regards.
Neelesh Agarwal
May 28, 2008 | Samsung SCX-4100 All-In-One Laser Printer
146 people viewed this question
