Question about ViewSonic VP920b 19" LCD Monitor
VG930M-3 Taking base of this monitor...
How do i remove the base of the VG930M-3? I am trying to send it back in the box to be repaired. Please help ASAP. Thank you!
After a chat with a Viewsonic tech and pulling out a lot of screws, this is what I discovered you have to do;
Find a secure place to turn your VG930M upside down, like on an armchair.
Undo the central screw on the base and remove the rotating black plastic plate.  Make sure you know which way it goes back on again.
Remove all the screws on the metal plate, something like eight around the circumference and another two which attach to the LCD support column. (You were never just going to pull that base off!).
Now for the tricky bit! The support column has two extensions that extend down into the base and click into position.  You have to get a flat blade screwdriver and push one of them towards the centre while trying to lift the base just a little away from the support column, so that it is unclipped.
Then you have to do the same with the other extension, while lifting the base a little. The base should now pop off.
Not as straight forward as some screens but achievable!
Good Luck!
Posted on Sep 09, 2009
Ok heres the deal i have 100 clients and they all had the same monitors VG930M one by one they are all going out one month it might be 3 monitors the other month it might be none but they are all the same...
This model and other Viewsonic monitors failed due to bad caps as you can see here:
http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VG930/
You should get capacitor kits (do not get the caps from Radio Shack, they are not low ESR type):
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. He also has the video on how to replace bad caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
I hope you know how to solder and have all the needed tools.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Sep 07, 2011 | ViewSonic VG930m LCD Monitor
I got a vg930m veiwsonic monitor and i try playin music and doing other tasks and i get no sound out of the built in speakers do i need a audio cord to get sound or what do i do
Yes many monitors (with the exception of some HDMI connections) require a separate cable to connect audio to the built in speakers on the monitor. I hope this answers your question.
Mar 16, 2011 | ViewSonic VG930m LCD Monitor
Taking stand off screen
The base can be removed by pressing the tab on the back of the stand. I do not think that the actual "neck" of the stand can be removed.
I found a manual here (has a few helpful diagrams): http://www.retrevo.com/support/Acer-X223W-Monitors-manual/id/23224ci553/t/2/
Mar 01, 2011 | Acer 22" X223w LCD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
My VG930M will not power up...is it fixable
In mine, there was a 1000 micro F capacitor in the power supply board that was damaged. You can tell which one it is by looking at their top. The bad one looks like it inflated and blew up.
I replaced it and it worked fine for 1 year so far.
The power supply is the one that is boxed in. You will need to remove the cover to acces the cap. I bought mine at Radio Shack for $1,59.
Good luck in taking it apart.
Jun 27, 2009 | ViewSonic VG930m LCD Monitor
How do you remove the outer case on Viewsonic VG930M-3 LCD
kauffman014, As far as opening the monitor up you may want to visit YOUTUBE and search for lcd monitor repair/ disassembling monitor/ or something like that. I did see a 9-11 min video there that was fairly good on un-snapping the rear cover from the front bezel of what I think was a DELL unit. Also visit electronicrepairguide.com run by a jestine yong. don't pay any attention to his ad to purchase repair course in lcd/fpd servicing!! only look at the pic's of the insides of lcd monitors and the power supply boards/inverter boards. On gateway's, and dell monitors the pedestal must be unscrewed from the rear cover first. The pedestal is really screwed down to the steel FPD chassis that covers the circuit boards and provides a ridgid mounting surface for the unit as a whole. Work on a flat surface with screen facing down on a blanket or lots of newspaper to prevent maring of the FPD!
There should be some phillips screws that fasten the steel shield to the left/right sides of the FPD frame. Once you get down to looking at the Switch-Mode-Power-Supply (smps) board look for large filter capacitors (electrolytic polarized aluminum can) that have the tops of them bulging upward as compared to normal ones that are flat. You will also need to inspect the bottom (solder side) of the board where all the leads of the components from the top side are soldered. You are looking for very thin hairline 'thermal' and or 'vibration' circular FRACTURES around the leads of the larger and bulkier (heavy) components. Yeah...use a big magnifying glass or better yet a 10x or 20x inspection microscope. One last thing, I highly recomend taking digital pic's as you disassemble the unit so it can be put together again without leftover parts. hope this info helps you out. Get back to me if you find out anything. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Mar 27, 2009 | ViewSonic VA1930WM LCD Monitor
Acer p221w monitor removing base
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
Aug 06, 2008 | Gateway FPD2275W LCD Monitor
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
ViewSonic VP920b 19" LCD Monitor Logo
416 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
