Question about HP PhotoSmart M627 Digital Camera
Lens error m627-30
Hello, i have a problem with my camera hp m627, have an lens error m627-30. can you help me plz?
  • 2,071 Answers
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
3 Suggested Answers
SOURCE: camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Posted on Jul 31, 2008
  • 102366 Answers
SOURCE: camera hp m627
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
Hello. I want to purchase a nikon coolpix S3000 model camera but my friends told me that this model of nikon has lens problem..so i want to confirm this. plz help me..thank u
I work at an authorized Nikon service center and I don't see many S3000 models coming in for repairs. Most camera point and shoot models that have an extending lens are subject to lens errors. Most of those errors are also a result of shock or impact and not manufacturer's defect. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 07, 2011 | Nikon Coolpix S3000 Digital Camera
Hello, i have a problem with my camera hp m627, have an lens error 627-30. help me please!
When a lens error occurs, it is generally due to a 'binding' of the gear inside the camera which needs to be serviced by hp.com.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864899&tmp_track_link=ot_faqs/top_issues/en_us/c00864899/loc:3&lc=en&dlc=en&cc=us&product=1147860&lang=en
The above tells how to do a power reset, but if that doesn't work then try to have it serviced by hp.com.
Call 1-800-HP-INVENT
Aug 14, 2010 | HP PhotoSmart M627 Digital Camera
Hello my name is vanessa , and im 11 years old. My camera has a very bad lens error! My camera is a Photosmart M527 Camera. My Camera is stuck when you take a picture. and now its all messed up. Please...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Feb 24, 2010 | HP PhotoSmart M627 Digital Camera
Hello frns i got err in my camera D80 control panel plz
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
NOTE: Please rate our help to keep this free service online
Sep 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
HELP ME FIX CAMERA BEFORE HOLIDAYS PLZ
go to rent a center and tell them you would like to rent a camera to own (NOT SHORT TERM THOUGH!!!!!) you will get charged initially a month for this. if you would just rent the camera like you want to buy it later there will be no hassle and by the way while your renting it(say it's been a few days after you've had the camera) ask if their service dept will fix the product for you. they will for possibly a small fee up front and then you tell them you would like an est. before anything is done with your camera! DO NOT mention you need it short term never say that
Dec 20, 2008 | HP Photosmart M525 Digital Camera
Zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Sep 23, 2008 | Fuji FinePix S7000 Digital Camera
Camera hp m627
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Camara hp m627
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 29, 2008 | HP Photosmart M425 Digital Camera
Open Questions:
See all HP PhotoSmart M627 Digital Camera Questions
HP PhotoSmart M627 Digital Camera Logo
925 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
