In order to use an SR-50 Personal Receiver must there be installed a transmitter.  If so, to what specifications.  I
  • 2,071 Answers
The PST-170 belt pack transmitter may be set to any one of the 17 channels, and operates on frequencies in the 72-76 MHz band. It is lightweight, battery operated and includes a small electric lapel microphone for convenient portable use. The PST-170 has two audio input jacks. The Auxiliary input is designed to allow audio devices such as teachers aids or tape players. The second jack is normally used for microphone and is located on the top panel. The channel is displayed on a backlit LCD and can be locked to prevent accidental changes. The PST-170 also includes the E.D.R. feature for improved sound quality and intelligibility.
Hope this may help;
Posted on Aug 25, 2008
    Genius:
  • 1,269 Answers
Definitely you need a transmitter coz you have a receiver
http://www.shopwiki.com/detail/d=Telex_SMP-2_Assistive_Listening_System,_PST-170_Transmitter,_SR-50_Receiver,_HED-2_Earphones_(B000Z7TDJM)/jumpToFirst=t/
  • 6,487 Answers
Yes you need to install a transmitter in order for it to work, transmitter like what you can find from this link will work fine http://www.alectrosystems.com/shop/data/Soundmate.pdf
Hope that helps..........
    Master:
  • 788 Answers
Telex sells the ST-300 base transmitter to use with the SR-50 receivers and it's microphones. See here: http://wirelessmicrophones.telex.com/wirelessmicrophones/products.nsf/pages/ST-300
How do you reprogram a new key for a 2000 Buick park avenue?
Transmitter Programming
Important: All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly.
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Apr 12, 2016 | Buick Cars & Trucks
How can I program my remote?
Remote for ? door unlock / lock , remote start , garage door opener .
If the door lock / unlock , panic alarm ,remote start . You can't dealer only . Need a factory scan tool .
Important: Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All Fobs.
Follow the scan tool on screen instructions.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Jun 05, 2015 | 2007 Buick LaCrosse CXL Sedan
How do I get the outside temperature to display on my Springield 91905-002?
If you read the instructions for your Springfield device, you probably will find a specific routine has to be followed to get the remote transmitter and indoor receiver communicating. Specifically, you should install batteries in the transmitter first then the indoor receiver. Wait for awhile for communication to start; it is not instantaneous.
Sep 13, 2014 | Springfield Measuring Tools & Sensors
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
I replaced the battery in the keyless remote and need to resynchronize keyless remote
Method 1 - No Tools Required, Program All Transmitters
Important: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only; #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the door unlock switch.
  4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to 4 transmitters.
  8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
  9. Operate the transmitter functions in order to verify correct system operation.
Oct 12, 2010 | 2003 Chevrolet Tahoe
Can't program keyless entry remote.
Try this,
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly.
Good luck and hope this helps.
Jun 23, 2009 | 1995 Cadillac DeVille
Key fob malfunction
The fab key it self may be bad at the unlock switch it self and the fab key needs to be replaced. You can try to reset the fab lock if you like and see if that addresses the issue.
Important
Once the Keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Sit in the vehicle driver's seat. (actually it’s much err from the front pass seat)
Important
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation
Good luck and hope this helps. If you have problems you can try asking the service department at the dealer where you bought the car or where you have the car serviced. Simple things like this most of the time will not cost much and may even be free of charge if you have a good relationship with them.
Jun 18, 2009 | 2005 Chevrolet Malibu
Remote wont work
GRAND PRIX KEY FOB PROGRAMMING INSTRUCTIONS
Important
Sit in the vehicle driver's seat. (actually it’s much eazy er from the front pass seat)
Important
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation.
Jun 17, 2009 | 2000 Pontiac Grand Prix
Akg sr 60
help me please akg sr60 , when torn on just mute
Dec 05, 2007 | Lands Phones
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
