Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak easy chare 5100 scanner
Im trying to scan some photos and when I press scan all that happens is the on/off light begins to blink. Nothing begins to happen, you dont hear any parts of the scanner moving. However I can copy the photo's directly from the scanner.
  • rpm809 Aug 30, 2008
    My 5100 not scanning. Went thru the whole process wih a "Tech" in the Plillipines? Reinstall, reconfigured, everything! Nice guy but no solutions, still not scanning. Any solutions out there
    Distressed in Texas
    Richard
  • jalang65bc Oct 02, 2008
    I am using MS Vista and my printer will not scan makes a noise as if it will but no lights in scanner bay it prints fine.
Same problem on new Dell Pentium Dual Core Vista machine. No fix found yet...
Posted on Sep 30, 2008
Kodak is the worse i have the same problems just wait till you need new ink
Posted on Sep 02, 2008
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
How can I scan a document. My 5100 AIO does not appear to want to carry out this function
In order to scan, the 5100 needs to be connected to the computer and the Kodak AiO Home Center software needs to be installed. Press the Scan button on the device and press Start to begin scanning. Refer to page 41 of the manual for detailed instructions. If you don't have the manual handy, you can view the PDF here.
Mar 25, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The scanner does not work on my Kodak EasyShare 5100 All-in-One Printer. Don't know how to make it work
Hi, if nothing happens when scanning w/ your printer.Please follow the steps below.
1.Verify that the scanner is working properly by copying a document first.
2. Open the Kodak AiO Home Center software.
3. Select Configure Settings.
4. Click Scan.
5. Click either the Documenttab or PictureTab depending on the file you want to scan.
6. Under File Save Setting, sure that the Prompt for filename and location is selected.
7. Click Apply then OK.
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
On a kodak 5100 printer how do I scan a document to the computer to use ss an attachment for E Mail?
Thank you for allowing me to assist you in this question. Below is some basic information on how to scan with this printer. The Kodak Home Center software will save the file into a directory into your computer and you can use your email program to attach that file into your emails.
To scan to a file
1 Set the Default scan destination to File with the Kodak Home Center software.
2 Place your original face down in the right front corner of the scanner glass.
3 Press Scan.
4 Press Start. The original is scanned and saved to a file on your computer according to the scan settings in the Kodak Home Center software.
To scan to an application
1 Set the Default scan destination to Application with the Kodak Home Center software.
3 Press Scan.
4 Press Start. The original is scanned into Kodak Home Center where you can open it with the application of your choice.
Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can you scan old slide photos of a 5100 Kodak Aio?
You can set them on the scanner glass and press the scanner button one at time and then edit each one as necessary.
Dec 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot find a default setting for scanner
by chance, is that printer plugged into a power strip? that can make a scanner NOT work.
http://tinyurl.com/6qcpgy
Jul 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
KODAK EASYSHARE 5100 SERIES
a blinking yel light w/ "F" on display means MEDIA SENSOR FAILURE
"P" PRINTHEAD FAILURE
"S" SCANNER FAILURE
Mar 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
