Question about Gateway Computers & Internet
Need to now how to wipe out hard drive and start over
  • 70 Answers
If it is your main hard drive you need the operating system disk and drivers put in the drive and follow instructions if you just want to wipe a drive go on my computer right click on the drive and then click format this is only to be used for a secondry drive
Posted on Aug 25, 2008
How do I wipe the hard drive of konica minolta bz-c353
Take it out and use your PC or Laptop to wipe out/reformatted. If the hard drive contains sensitive data then you will need to find a program that will wipe out those completely.
Try this method
Nov 21, 2013 | Konica Minolta BZ-C353
Tip
How to Completely Erase a Hard Disk Drive
Erasing a hard drive is a step that most computer users overlook. Just simply going through your data and using the delete key in Windows does not entirely delete the data. This just simply removes the shortcuts making it not visible to the user. If a person wanted, they can easily use software to obtain the data off the hard drive.
Fun Fact
A study was done and were 158 used disk drives were collected and the data retrieved. The two students found 5,000 credit card numbers, medical reports, detailed personal and corporate financial information, and several gigabytes worth of personal e-mail and pornography on those drives.
Disk Wiping Methods
There are two common methods for erasing data. These are formatting and wiping. Formatting a hard drive will not erase the data on the disk but will delete the address tables making it more difficult for average users to see the data, however, a computer specialist who is skilled can obtain some or all of the data using tools. Disk wiping is a more effective method and basically write over the data with 1's or 0's. The more times the disk is overwritten the more secure it is.
Disk Wiping Software
There are numerous free software utilities out there that will wipe your hard drive. I will recommend two programs and briefly go over them.
Eraser - Click here for download
Eraser is a advanced security tool for Windows that will completely remove data from your hard drive. It has a simple to use interface and uses multiple wiping methods such as Peter Gutmann's paper Secure Deletion of Data from Magnetic and Solid-State Memory.
You can use this program to delete files, folders, recycle bin contents and even free space on a drive. Click here for a quick start guide which will give you the basics.
-You can even use Eraser to wipe your flash drive.
Darik's Boot and Nuke - Click here for download
Darik's Boot and Nuke is basically software you boot your computer into. You can load the software into a floppy disk, CD, or USB stick if supported by your computer. Once you boot into the program, you select the wiping options and it will do the work. This is an effective program and I have used it before.
In order to boot your computer to the software you will first need to load the software on the media(usb/cd/floppy) described above then insert the media into your computer. Turn off your computer and as it is booting up you want to go into your computer BIOS. Usually, it will tell you what to press to get into BIOS during the boot up process. Once inside the BIOS you will need to change your boot order so it boots to the media device first. Once done, exit the BIOS saving your changes and the computer will boot into the media and start the data wipe software.
Tips
-If you are installing a new operating system I recommend you first wipe the hard drive using the methods described above, then formatting the drive for the new operating system. If you are giving away the hard drive or computer, I would recommend you wipe the hard drive before doing so.
I hope this article was informative. Be sure to check out my other tips and tricks by clicking on my name then clicking on "Tips" under my profile.
Regards,
G33k
Keywords
how to erase a hard drive, format hard drive, erasing hard drive, how to wipe a hard drive, how do you erase a hard drive, wiping a hard drive, erase hard drives, erase a hard drive, wipe out hard drive, wipe hard drive, how to clear hard drive
on Jun 21, 2011 | Computers & Internet
Won't start
the wipe out probably removed your operating system too.install a new os
Jan 05, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
How can I completely wipe my wd passport hard drive and start over? there are files and weird backups that i just need to get rid of and totally start fresh but they are protected. help!
With the drive connected to your computer, Open up My Computer, located the drive you want to wipe, right click on it and select Format, you can do a quick format. This will remove all data from the drive so be sure you do not want any data that is on it. This will also remove the WD files that came on the drive as well. If you need these files just copy them to your local disk temporally format the drive and then move them back.
Jan 05, 2010 | Western Digital My Book Essential 500GB...
How do you wipe the compaq presario m2000
I'm not sure if you are wiping it to start over or to sell/give away.
Many newer machines have a Recovery Partition, usually your "D:" drive.
Access the System Recovery partition from the Start-All Programs-System Recovery-System Recovery Menu. Following the prompts will allow you to reformat the computer and reinstall the operating system and all software as it came from the factory. From that point, if you don't want any of the factory junk, you'll need to uninstall it yourself.
If the Recovery partition is missing, (usually a D: drive) , then you'll need to have the original Recovery discs which were created when the computer was new.
If you simply want to wipe it, use a disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads.com to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
Read more: http://pcs.suite101.com/article.cfm/wiping_your_computer_hard_drvie#ixzz0RZDlV3Qr
Sep 19, 2009 | Compaq Presario M2000 Notebook
Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Sep 08, 2009 | Western Digital My Book Essential 500GB...
Trying to wipe the hard disk of an old Compaq Evo
You message cut out. It's very difficult if not impossible to wipe a hard drive when you're using that hard drive. You need to get a program like Gparted or Disk Manager. The first is free and can be downloaded.
Mar 27, 2009 | Compaq Evo D500 PC Desktop
Wiping the hard drive
i presume you have not formatted the drive yet. first make sure there is a restore partition on the drive.... after that go into the start menu and look for a menu item called restore or restore tools .... i'm not 100 % familiar with that computer but the basics of restoring the system are generic.
Robert
Dec 16, 2008 | Toshiba Satellite M40-S417TD Notebook
Reformat
Insert the winxp disk and boot from that, when prompted hit any key to boot from cd.
Win xp will start to install choose to delete the partition, confirm delete.
then press enter to install to that unallocated partition, choose format to NTFS.
Follow the prompts and it has formated the hard drive and will install XP.
Apr 30, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
