Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Profile PSS26NSTC SS.
Water works, ice made, won't dispense. Buttons light up when pressed. Temperature ok in both sides
  • 1 more comment
  • thekdi Sep 03, 2008
    I have the same problem on GE Profile Arctica PSC23SGRD stainless steel refrigerator.
  • verhagej Oct 03, 2008
    I have the same problem on the same model (PSC23SGRD). Water dispenses intermittently, but ice does not dispense. No motor sound when dispenser switch is pressed.
  • Anonymous Nov 24, 2008
    I have the same problem with a PSS26NG ss
22yooper
  • 828 Answers
SOURCE: Icemaker just stopped making ice
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
Posted on May 15, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
Sea Breeze
  • 4655 Answers
SOURCE: The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Posted on Jul 23, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
No ice or water from GE Profile side by side refrigerator freeze
I had this problem and did 3 things to correct it:
1st: I changed out the Main Circuit Board in the back of the fridge.... very easy to do, but that wasn't the problem.
2nd: I changed out the Dispenser Circuit board, which is behind the touch panel. Also very easy to do, just snaps out. but that also wasn't the problem
3rd: I checked the wire harness connection point located behind the grill at the bottom front of the fridge underneath the freezer side. This is also very easy to do, and son of a ..... that is what is was. Moister from mopping the floor had started to corrode the connections. So I purchases a cheap 3 wire plug and cut out the old and spliced in the new. You don’t actually need the plug, you can hard wire direct but if you ever have to take the door off you will have to cut the wires.
So now I’m the proud owner of an extra functioning Main Circuit Board and Dispenser Circuit board if anyone is in need.
Nick
Jun 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Psc23sgrd ss ice/water dispenser not working
It is possible. When you put hit your glass against the paddle to you hear the switch click? And can you still select between water, cubed, and crushed ice? Also does the light by your glass come on when you but your glass against the paddle?
When you put your glass on the paddle it pushes in a microswitch. That microswitch will power the light if it is working and also sends power to the board you are talking about to dispense ice or water depending on what you have selected.
Nov 03, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
217 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
