Question about HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 insists ink cartridge is empty; won't print
HP Photosmart D7160 has worked well, but when last yellow ink cartridge showed empty, I replaced with genuine HP cartridge. The printer immediately replied the ink cartridge was empty. Thinking I might have a bad cartridge, I inserted a second, and a third! The printer is not sensing the replaced ink. I cannot run a printhead cleaning; I cannot run any black only printing. I have probed the inlet and outlet for the cartridge on the printer (thinking there might have been a clog) but no success. I cleaned the metal contacts on the cartridge to insure contact, but still no reset.
Can anyone advise how to get out of the Catch-22 and get the printer to reset and sense the new cartridge?
  • 2 more comments
  • Mark Aug 28, 2008
    I have reviewed the tendered solutions but cannot get the printer to respond; I replaced the yellow cartridge before it stated it was totally empty, but it will not recognize the full cartridge... keeps saying it's empty. I have to think the pump is not operating. Any way to resolve this?
  • Anonymous Mar 15, 2014
    hp photosmart d7160 printer black not printing
  • Anonymous Mar 26, 2014
    how do I open the HP3110 printer to clean it
  • Anonymous Mar 27, 2014
    Installed a new black ink cartridge, but still get the "E" and little diagram shows empty cartridge
  • HP Master
  • 1,879 Answers
Common issue with inkjets :
>cart not recognized - you already did what you can up to probing the contact plates for the cart & printer.
>this type of issue is bound for service / warranty - as the details of the logic board, the internal connections inside the printer is not available for public viewing.
Posted on Aug 28, 2008
  • HP Master
  • 19,396 Answers
HP cartridges have region settings and ink counter on chipset, this is causing the problem.
Sometimes , when hp printers lock up, the only way to unlock them is by entering a reset code provided by HP.
Call them by phone, they will ask you model number.
US number : 800-752-0900
UK number : 08443690369
For other regions see Contact HP worldwide (in English)
After asking your model number, they will give you a reset code for your printer, and problem is fixed.
Thanks
  • HP Master
  • 6,487 Answers
You can check this link for some steps to solve your concern http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00819086&lc=en&cc=us&dlc=en&product=1153477
By the way you can also check if other cartridges are empty that might be causing the problem..
Hope that helps....
Posted on Aug 25, 2008
  • 2,071 Answers
Are you using compatible cartridges? If so have you removed any tape that covers the vent hole if required. Many compatibles need to have a piece of tape removed. If you forget the ink cant get out as the air can't get in.
If it not a piece of tape and there are no flashing lights it could be that the nozzles are blocked or the wick has dried out.
You can do a manual cleaning using some kitchen paper and a little solvent and a small plastic bag.
The first thing we need to do is get the head away from its parking position. Switch on the machine and when the head has moved away from its park position, remove the power lead.
With the top of the machine open, you should be able to move the print head carriage by hand.
Look to the right where the head carriage is normally parked and you should see the pump cap area. It will be a black looking spongy pad covered in ink.
Now take a piece of kitchen paper and fold it over a couple times to make a pad approx 3"x1". Now lay this pad over the top of the pump cap and fold the left edge down toward the base of the machine as in image one (the tissue is the yellow bit in the image)
Now take a syringe or similar and put some solvent into it. The solvent I use is JR Ink Jet Cartridge flush as seen on ebay and the like. If you have any ammoniated window cleaner like Windex you can use this. Put the solvent onto the tissue making it quite damp, but not totally soaked.
Manually move the print head GENTLY back to its park position. The pump cap will try to raise up to meet the bottom of the print head as you move it back. Be careful no to force it or you may break something.
What we are trying to do is bring the solvent dampened pad into contact with the print head. Once located, leave the pad for 5 or 10 minutes whilst the solvent does its trick.
Now move the head away from park - again being gentle. You should now see the pad is a horrible black lump of mush. Pick it out and put it in the plastic bag ? where a glove or use tweezers or pliers.
Repeat the process again but this time let it to soak for just about 1 minute. You should now see the individual ink colours soaking into the pad. If the pad is still black, repeat the process a couple more times.
Once you have some evidence of the individual colours you can run a head clean via the driver or printer control panel.
Then print a nozzle check sheet and if all has gone according to plan you should have a full complement of lines.
This method is applicable ONLY for loss of a few lines on the nozzle check sheet. If you have loss of all the lines in a single or multiple colours, you need to investigate further. It is possible that the pump has failed, the pipes are clogged or something else is causing the problem.
If that does not sort it out, tru using a syringe to put a couple of drops of solvent onto the wick. Its the black plastic spike that stick up and goes into the bottom of the ink cart when it is installed. Put a cupole of drops in, put the cart back in and leave it fpr about 10 minutes. The re-try a head clean using the driver/status monitor.
There is another possibilty after this which relates to a hardware problem but this generaly causes a loss of all ink.
Hope this may help;
Regards,
VOTIT
  • 2 more comments
  • LORETO LACARON
    LORETO LACARON Aug 25, 2008
    There's a reset procedure for clearing the message.
    Waste Error Reset:
    Unplug Power Cord
    Hold POWER and RESUME buttons
    Plug in Power Cord
    Release buttons
    Open front door of printer
    Hold the CARTRIDGE and RESUME buttons
    Press POWER
    Release all buttons after the beeps
    Press CARTRIDGE once
    Press RESUME
    This should reset it and you should be good to go for a long while.
    Regards,
  • LORETO LACARON
    LORETO LACARON Aug 28, 2008
    Just click below for more information...
    Ink Cartridges Empty
    Ink cartridges empty message
    Color Image Prints in Black and White
    The printer is working, but a color image prints in black and white.
    Wrong Colors
    The printer is working, but the colors on the printed output are not correct.
    Set Up the Printer Hardware
    Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges.
    Colors Bleed into Each Other
    The colors in the printed output bleed together or seem muddy.
    Streaks or Lines in Printed Output
    There are streaks or lines on the printed output that are perpendicular to the direction the paper moved through the printer.
    'Ink Cartridge(s) are Expired' Message ...
    The 'Ink cartridge(s) are expired' message displays on the control panel display. Follow the steps to resolve the issue.
    Check Ink Levels
    Check the estimated ink level in the print cartridges.
    HP Photosmart D7160 Printer: Manuals
    ... HP Customer Care | HP Photosmart D7160 Printer | Product information HP Photosmart D7160 Printer ... HP Photosmart D7160 Printer | Product information HP Photosmart D7160 Printer: Manuals About these files: These manuals are ...
    Regards,
    VOTIT
  • LORETO LACARON
    The message Ink Cartridges Empty or Black Ink Cartridge Empty appears on the computer. The rest of the message offers various options:
    • Print with black ink only - the printer will replace colors with grayscale
    • Continue with other colors - text and photo quality will differ from those printed when using all cartridges
    • Cancel printing - no option to continue until cartridges are replaced
    In most cases, this message will not appear in the middle of a print job. In the rare case that it does, the print job must be cancelled.
    Solution
    As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue
  • LORETO LACARON
    LORETO LACARON Sep 01, 2008
    Did the solutions from all of us experts solved your problem if
    not then let us know the current updates so all the fixya experts can
    assist you further.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
I just replaced the yellow ink cartridge but it
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jul 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge, the printer says the yellow cartridge is empty, when it is a new cartridge.
try to refill your new cartridge with yellow ink. Refill you cartridge once only.
Feb 25, 2010 | HP Photosmart D7160 InkJet Printer
Yellow ink cartridge will not print
The print heads must be bad. I had the same problem. Still under warranty and HP replaced printer with rebuilt unit
Feb 23, 2009 | HP Photosmart D7160 InkJet Printer
Photosmart D7160 shows yellow empty even with NEW cartridge
Printhead problems are more common than perceived. Have you disconnected the power cord for the printer to flush the built-in board? Disconnect the printer USB cord as well. If this doesn't resolve the problem call for an RMA. Printheads are not inexpensive.
Jan 20, 2009 | HP Photosmart D7160 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
HP D7160
replace the carrage unit in the printer
May 26, 2008 | HP Photosmart D7160 InkJet Printer
New Ink cartridges registering as empty ...
Is it an HP printer? We had the same problem at work with print cartridges purchased at Staples. They have a major quality control problem. Your new print cartridge may be empty or dried out (died on the shelf). It's my problem at work, as I have over 80 HP deskjets, and Purchasing still insists on buying the Staples cartridges rather than the HP.
Sometimes if you shake a print cartridge really hard it may correct the problem. However, I would buy or borrow a black HP print cartridge and try it out in your printer. Works almost every time on the job. Good luck.
Apr 17, 2008 | Computers & Internet
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7160 InkJet Printer Logo
1,541 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
