Question about Whirlpool Washing Machines
Agitator not working properly
I need to know to take apart an agitator on whirlpool model washer-LSQ8243HQO. Thanks
  • 5,911 Answers
This is a fairly simple process. Just follow these steps:
1. Remove dispenser cap by pulling off.
2. Under the dispenser cap is another plastic cap with a washer. Pull this out to expose the agitator bolt underneath.
3. Using a socket and rachet (easiest method) remove agitator bolt and remove entire agitator by pulling from the bottom flanges and lifting straight up.
If you go to searspartsdirect.com and type in your model number, there's an excellent drawing of your agitator and components under the "Agitator, Basket and Tub" heading. Use this as a reference for reinstalling any parts.
I hope this helps you. If you still require assistance, please let me know.
Posted on Aug 25, 2008
I have a Whirlpool washer... model number # LSQ8243HQO The top part of the agitator is loose. The bottom part is strong. I think I need what they call dog ear replacements. Can you help me?
yes sounds like the dogs to me.
to replace them,remove the cap at the top off of the top of agitator by pulling it up (no tools required) then remove the clear plastic cover by pulling on one of the two tabs in it,remove the bolts using 7/16" socket and pull the agotator out of the machine by gripping it at the bottem.seperate the upper portion of agitator by pulling it upand the dogs will be located under the clear plastic,to replace them seperate the top barrel of agitator a cam that holds all (4) dogs will come out remove the retainer over the dogs install new ones and reassamble in the line up upper barrel and main agitator you will (2) tabs on main agi. and (2) corosponding slots on barrel line them up and snap in place
Jul 14, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
My whirlpool washer lsq8243hqo lid swith seems to be acting up and washer will not adavance from agitation to spin and rinse without pushing lid down. when i do that sometimes it stops and clicks and then...
There is likely to be a problem with either the lid solenoid/lock or the 'door/lid closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Little AGITATION clothes not getting clean, Spin cycle is fine
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
Oct 23, 2017 | Whirlpool Washing Machines
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II top of agitator don't agitate.
This problem is caused by worn agitator dogs. The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The upper portion of the agitator you mention is called the "auger". The small teflon dogs have teeth on them and act as a clutch to drive the auger when the agitator is in motion. The teeth wear out and become smooth, causing the auger to slip. The replacment part number is included in the link I provided. You can choose to order on line at searspartsdirect.com, appliancepartspros.com or repairclinic.com. All three sites offer competitive pricing, so shop all three for the best price. If you do not wish to shop online, take the part number provided to your nearest appliance parts retailer. This is a common part, they should have in their inventory.
I hope you find this information helpful. Let me know if you have further questions.
Apr 12, 2009 | Whirlpool Washing Machines
Agitator on Whirlpool Ultimate Care II won't agitate
you can replacethe gears taht cause the agittion called agitator dogs part number 80040, probly $20.. reomveth efabric softener( swift smack with thepalm of you hand) and then remove the agititor with a 7/16 screw down the center shaft. the agitator will "split to reveal the "dogs" fairly easy repair
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Jan 22, 2008 | Whirlpool LSR6232J Top Load Washer
Washing Machines Logo
219 people viewed this question
Dan Webster
Dan Webster
Sal De
