Do you here a clunk when you turn the key to start? If so that is the starting coil pulling in, if not the starting coil may be bad or battery drained or safety switches in wrong position, but check battery voltage and connections. I had a friend recently leave the lights on and drained the battery. If battery drained charge it or jump start your mower and mow for a while to charge. Also check to make sure your safety switches are in the right place. I had another friend that had a kid playing in her garage and he had engaged her blades and the safety prevents starting the mower with blades engaged. Also if you have an electrical engaging of blades versus a manual if the blades were left engaged while sitting it will drain the battery also.
