Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
There is air when I make a shot and it comes out watery.
Have you tried prepriming the coffee (dampens and gives better flavour). Also, you can make the machine push the old water out of the system when it first starts up...........see manual
Posted on Nov 23, 2008
When I use the filter after a previous cup and it is still wet the coffee comes out very watery and undrinkable. When the filter is dry in the morning the coffee is perfect.
I'd suggest you try tamping with a bit more pressure, watery coffee is typically the result of water getting "around" the ground coffee as opposed to getting forced through it.
Feb 16, 2014 | Breville Die Cast 800ESXL Espresso Machine
Watery espresso (puck?)
As far as repairs, Sounds like the seal is wore out and is causing air leaks,
For repairs I need make and model of the machine to locate service, or you could enter it in on the main home page of this site.
Nov 15, 2007 | Gaggia Classic Brushed Stainless Steel...
My GoldStar Air Conditioner Model WG5005 makes a watery sound and splats of water shoots out. What does that mean?
Hello, this could either be a clogged drain if the unit has one, or the unit is not tilted back enough in the window if the unit does not have a drain.
Jul 02, 2012 | Heating & Cooling
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
When I try to make an espresso shot, it runs out very fast and watery.
The coffee needs to be ground finer and tamped harder.
I grind my own coffee. I have never found any supplier that grinds their coffee fine enough.
Dec 28, 2010 | Rancilio Silvia Espresso Machine
The esspresso shots are watery
You need to adjust the grinder to finer and the amount of coffee grounds.
Dec 26, 2010 | Astra 2000 Espresso & Coffee Maker
I have my Silvia for 3 years and for the last couple week, it gives me espresso watery with no crema. I havent changed anything for the last 3 years. Please help!
It definitely needs preventive maintenance once a year. There could be a couple of issues causing watery espresso. You could have a clogged shower screen or cracked porta-filter basket. They bypass valve from the pump could be leaking causing low pressure (check this by pulling a shot and seeing if water continually flows back into the tank via one of the water hoses).
Mike mikey@espressomachineexperts.com
Oct 15, 2010 | Rancilio Silvia Espresso Machine
Watery oil dripping from air filter
must be an older unit. This sounds like blow by and there is not much you can realy do about it short of completely rebuilding the motor.
Sep 13, 2009 | Briggs & Stratton Garden
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
42 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
