Question about Whirlpool GEW9200L Electric Dryer
Duet Dryer (GEW9200LW) Control Panel doesn't work (all the time)
I have a 3 yr. old Duet dryer. Recently the control panel has been working less than 5% of the time. The inside drum light always works. The control panel, hoever, seems to have a mind of it's own. Most of the time it won't work but, every once in awhile it'll somehow allow us to dry a load. However the next time we try it won't work. Do i replace the contol electronics? the user interface? will this problem keep happening after another 2yrs. or so? Thanks in advance.
  • 1 more comment
  • stink9025 Aug 25, 2008
    The problem is that the front electronic control panel does not work constistanlty. The inside drum light is on so the dryer gets power. The contol panel doesn't.
  • Anonymous Sep 04, 2008
    I have the same problem with mine.
    Dataman57
  • tutorisland Mar 15, 2009
    i have this dryer
    the control panel locked light stays on...nothing works
    tried on off at breaker over nite...still on pwr up this lite only
    plz help thx
    steve surrey bc funfit35 at hotmail
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
Duet Dryer (GEW9200LW) Control Panel doesn't work  - small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 2
Gas Maytag Style Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
rDuet Dryer (GEW9200LW) Control Panel doesn't work  - redarrow.gif class= Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE
Posted on Aug 25, 2008
Control lock button is on and will not clear to wash clothes
Hi, Whirlpool makes their control lock very confusing. Often times, people will look on the control panel and the control lock light will go on and they can not figure out how to unlock the control panel. They will try pressing and holding the cancel button and unplugging the washer or dryer to reset it. None of these options work. All you need to do is press and hold the end of cycle button for 3 seconds and the control panel will unlock. If that doesn't unlock your controls, then unfortunately your interface control board is just shorted and will need to be ordered and replaced to fix the issue.
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer is stuck on "Control Lock"
See if you can get into the diagnostic mode. If not, you will need to replace the "user interface" on the machine. Here is a link to the part if you should need it.
ACTIVATING THE DIAGNOSTIC TEST MODE 1. Make sure that the dryer is in the "Standby" mode (plugged in and all of the indicators are off). 2. Press the following control panel keypad sequence all within 5 seconds: More Time-Less Time-More Time- Less Time. 3. All indicators on the console should now be illuminated with "88" showing in the "Estimated Time Remaining" display, if this test mode has been entered successfully.
Dec 26, 2010 | Whirlpool Duet Front Loading Dryer Rack...
Control panel not working
Hi
Thanks for using FixYa. To reset the dryer you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. If still the issue is not resolved then unfortunately you'll have to replace the control panel. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Unresponsive control panel- Whirlpool duet dryer 4 years old
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Dryer
I have a whirlpool duet dryer GEW9250PW1 and the control panel wont come on, I have took out the circuit boards cleaned them with contact cleaner blew out the top and took off the bottom panel and blew it out, after all that it still wont come on unless you unplug it for at least 20 minutes.
Oct 07, 2009 | Dryers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
push and hold in far right button on conrtol panel( look closly you see control lock) hold for 3 secs and it will turn off
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9200L Electric Dryer Logo
802 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
