Question about Compaq Presario Notebook
Usb port whenever pen drive is inserted.my system get hanged. but with the same usb port i am able to use mouse.
    Genius:
  • 1,148 Answers
Ive got a flash drive that does the same thing ,,one day it does ,one day it dont,, do you have vista or xp ,,because i think its got somethin to do with vista ,,and some of them flash drives,, goodluck
Posted on Oct 05, 2008
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
I am unable to open my pen drive
try to format it.
go to controle pannel > admins tools > disk managmen >> device managment, right click ur flash drive and choose format.
or u can downlaod "hp drive key"
Apr 30, 2010 | Transcend (589307) Media
When i insert pendrive in my two three machines, machines get hang completly. i have tried same pen drive in other machine it works fine. I am using quick heal antivirus. please fix my problem its urgent...
Hi.
Kindly first check if your mouse works fine with the USB port if it does not then the issue is with the USB port which can be replaced . This happens due to short in the USB port board.
Feb 08, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Whenever I insert my pen drive into my pc,it restarts computer. what is the problem ?
if this is only happening on 1 usb port, there is a short in that port that is causing you PC to shut down. Your motherboard BIOS is probably set to reboot on power loss which means it will boot right back up if it shorts out.
If it happens on every USB port then your pen drive is faulty and I would refrain from inserting it anymore before you damage your hardware.
If the pen drive works on someone elses computer, then it sounds like the SOUTHBRIDGE chip (chip on motherboard that controls USB, PCI slots, firewire ports, etc) is going bad or is faulty.
Oct 01, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
System hangs by inserting pen drive
does other usb devices work fine on the same system please check if your pen drive is working fine on some other pc/laptop if it is working fine then you have to check with your usb ports.
Jun 09, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Whenever I insert a new wireless mouse or any thumb drive into a USB port my Aspire asks for a driver. Previously the drivers for these devices installed automatically.
You probably turned it off by accident. Go to Start > Control Panel > System > Hardware and choose "Windows Update" under "Drivers". Make sure either the first or second choice is selected.
May 28, 2009 | Acer Aspire One AOA150-1784 Netbook
System hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Driver
try with reinstalling usb driver by your mother board cd,and install chipset INF,
check in other pc to check weather your pendrive got faulty
regards
prasanna
Mar 08, 2008 | Electronics - Others
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
