Question about Lexmark Wheelwriter 3 Typewriter
Problem with Lexmark wheelwriter 3
It turns on fine but after typing for several minutes the print wheel will spin wildly and type a random letter or figure on the paper. Sometime you can erase it and let it rest and it will type okay, others it will do the spinning thing over and over so you just have to shut it off and quit.
  • Lexmark Master
  • 3,594 Answers
Remove the P/W and look for debris down in the slot it fits in, if you have some sorce of compressed air blow the printer out especially the P/W area. If this dosen't help you probably need a tech to relpace the sensor.
DickyO
Posted on Aug 26, 2008
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
I have an IBM Lexmark Wheelwriter 6 Series II 6784 Typewriter that is not typing the correct letter/number and at times, is not typing anything at all (no letters/numbers are appearing that I'm typing) We...
Try cleaning the sensor that lays behind the printwheel that tells the machine the wheel is in the home position, the sensor is in the print carrier. take wheel out and look down and you will see the sensor, clean it off with clean cloth. also put some white out on the top of the printwheel and see if it stops at the same place every time when you turn on and off.
Oct 05, 2017 | IBM Lexmark Wheelwriter 6 Series II 6784...
Lexmark Wheelwriter 1000 -Problem with wheel?
A few possibilities: The LED or sensor that looks at the primtwheel is getting weak, There may be debris on or under the PC board, the power supply is weak or rarely the flat white cable to the carrier is bad.
None of these are easy repairs, I'm sure we can repair it if you get it to us.
DickyO
216-241-0027
May 18, 2012 | Lexmark Wheelwriter 1000 Typewriter
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Wheelwriter 6
The plastic printer solenoid cap is probably broken, it is available but a little tricky to install.
DickyO
Jan 16, 2009 | IBM Wheelwriter 30 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
