Question about Malber WD1000 Front Load Washer/Dryer
How long can drain run be
I am installing a Malber WD1000. I would like to permanently connect it to the plumbing under the bathroom sink. The drain 23" from the floor and I can access both the hot and cold pipes there. The only problem is that the closest I can get the machine to the sink is 7 feet. Is that too far. The directions say 6 feet from the drain and 5 feet from the water source. I am hoping that there is a little room to extend those numbers.
Anyone have experience with this?
  • 3 Answers
No the pump cant handle the extra length in the hose
Posted on Sep 15, 2008
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
How do I replace water lines from bathroom sink to outside drain lines
Supply or drain? The supply lines will be routed either behind cabinets or through the floor. You can use a sharkbite fitting to connect the new water line to the old and then pull until you have reached the location to be connected. Then install the required fittings to properly connect. The drain lines do not go directly outside. They are directly plumbed into a holding tank and then the holding tank is plumbed out to a valve and then a drain fitting.
May 03, 2014 | Dutchmen 2013 Kodiak 240BHSL
I have the Malber WD1000,the wash cycle goes on but no water pumps out, a couple drops come out . How do i fix it?
No water fill
1.water valves closed----turn on valves
2. Hoses kinked---unkink hoses
3. Screen in fill hose clogged----clean out screen
4. No power to fill solenoid---replace solenoid
5. Faulty water level control---replace control
6. Machine did not turn on----check control & power outlet
Water will not drain from machine
1.kinked or clogged hose----clean drain hose
2.pump does not run----readjust & tighten pump-drive mechanism
3.suds lock----remove suds,, add cold water
4.faulty transfer valve---replace
5.defective timer----replace
6.loose belt---adjust belt
Sep 22, 2011 | Malber WD1000 Front Load Washer/Dryer
My Malber WD1000 over floas and does not dry = can you advise me
First off, I have found that my machine gets clothes 90% dry (or 75%). Also, when I first installed mine, I did not properly drain it. The drain hose you notice comes out the bottom of the machine, goes up to the top and then goes back down again. I had to take the hose from there back up again to create a trap that held the water so it did not flow back into the machine. (I figured this out by disconnecting the hose entirely and letting the water run onto the ground.
Hope this helps.
Feb 11, 2010 | Malber WD1000 Front Load Washer/Dryer
I lost manual . there are a lot water inside. how
To get the water out , bring the machine forward
Take the drain hose out of the waste pipe
Remove any clips holding it to the back of the washer
Lower the hose into a bucket and the water will drain out under gravity
As for the knob it is a replaceable part but you will need to contact Malber
Nov 13, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Water in drum after turning off
could be a leaking fill valve ..not shutting off good after shutoff
Dec 08, 2008 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
128 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
