Question about Frigidaire FGFB75D Gas Kitchen Range
Kenmore Self Cleaning Convection Range C880 639539J0
I had just turned off the oven and a few minutes later there was a popping noise and a flash of light. The clock panel is blank and the stove appears to be dead. What could be wrong? Do you think it is worth trying to repair or we need to buy a new one.
gwshaw71
  • 83 Answers
SOURCE: self clean
if your oven has a clean cycle it will say clean on the knobs or a button if digital.self cleaning cycle turns on both broiler and bake elements and temperatures up to 1500 deg.and disintegrates everything in oven also you will have a door lock on oven door
Posted on Nov 25, 2007
  • 126 Answers
SOURCE: Problem codes for self-cleaning ranges
e2 f3 oven to hot
e1 f5 check door / latch switch
if its working now dont worry
Posted on Dec 10, 2007
huuum
  • 750 Answers
SOURCE: Frigidare Gallery Range 1998 model convection/baking drop in range
Hi Juliett
huuum At your service!
You said,
You came home and the was no display showing - control panel seems completely dead - last time we used the stove the display was so dim it was hard to see.
_______________________________________________________________________________
I advice that you are correct!
From what I have read it sounds like a board should be replaced and the cost would be roughly $450 - is it worth it to call a tech or should I just buy a new one.
This like an expensive repair for an old range!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Buy New and save!
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Frigidaire has some good rebates this month!
Some Up to $750. cash back
Bless You,
huuum
Please give me a solved rating for this good advice at our web site before you sign off!
Posted on Sep 13, 2008
aborcass
  • 2651 Answers
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
Posted on Mar 18, 2009
  • 8 Answers
SOURCE: lost directions on my stove. How do you clean the
Their should be a knob on it that says self clean or just clean set and you need to lock the door shut, when the cleaning is complete the door should unlock automaticly.
Posted on Nov 21, 2009
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Tip
Electrolux Model EI30GF55GSE Self Cleaning Doesn't Work
When using the self cleaning feature, you may see the panel flash remove shelves then go off after a minute. The solution is that there is a bar in the back left of the oven that is connected to the self cleaning sensor. After sitting a few months it may get stuck. Try moving or flipping the bar back and forth a few times. you should hear the sensor clicking . Then try to clean the oven. It worked for me.
on Oct 16, 2011 | Electrolux 30" Self-Cleaning Freestanding...
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Kenmore Elite Range door locked error message
Hold down the number three button until the LOC message disappears and then the door will open.
Dec 23, 2007 | Kitchen Ranges
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Frigidaire FGFB75D Gas Kitchen Range Logo
413 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
