Question about Olympus Camedia C-450 Zoom Digital Camera
Focusing distance in macro mode
What is the focusing distance in macro mode?
    Master:
  • 852 Answers
An image may be too dark if a finger is obstructing the flash or the lens.
Posted on Sep 01, 2005
    Master:
  • 852 Answers
On a D-565 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
The distance focus ring, is it supposed to turn all the way to the macro symbol when you are focusing on a subject that is very close?
If you're right "on top" of the subject - then, yes - it should indicate "macro". Macro focusing is for "very up close" photography and is exactly as you describe. You simply physically move the camera a little closer to or further from the subject to focus.
Not all lenses are capable of macro focusing. The vast majority of these non-macro lenses are required to be at least a couple (or more) feet away to focus. Macro lenses on the other hand can usually get just inches away - which is a great capability.
Enjoy your macro lens!
Oct 12, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Focus in Macro mode
1. Do not use the zoom while using macro. 2. When clicking the Macro button, click it again, only for 2 more seconds at the second click, it goes to 'Super macro' mode for zero distance. This works in the Canon S3 IS, I hope it will help you in the older S2 IS. 3. Use a tripod. 4. Use the timer for no movement when using a tripod. 5. Try using the manual focus, it does the trick when the camera doesn't focus automatically. Good Luck!
Aug 13, 2006 | Canon PowerShot S2 IS Digital Camera
Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
The minimum focusing distance
Shooting can be performed at a minimum focusing distance of 3cm. An approximate 2.1 cm x 2.8 cm subject can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
On a D-580 Zoom camera, the Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
On a D-575 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Using the Macro mode, it is possible to zoom through all ranges from telephoto to wide down to a minimum distance of 7.9 inches.
Sep 01, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Olympus Camedia C-450 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
