Gas boiler will heat water but will not heat rads
    Champion:
  • 254 Answers
Sounds to me as if you have air trapped inside the system. If you have steam traps they may not be working. You probably need to call a tech to look boiler traps can sometimes be complicated, and steam if not controlled right can be very dangerous.
Thanks
Zerko
Posted on Aug 30, 2008
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Some of the baseboard heaters don't get hot. It is an old (1970) boiler system. Is there somewhere on each individual unit to turn it on? I'm baffled, I just assumed the hot water would run through all of...
Hi.
No the water does not have to run through all of them....if you have what is known as a mono-flo system.
With this type of system there are tees that divert some of the water to the radiator and some of the water bypasses and goes on to the nest radiator and so on....
If you look on the radiators that are not getting warm or any of the rads for that matter you will see a silver bleeder valve. Some of these take a "key" to open and some just have a screw driver slot.
If you open the beleeder you will probably get air out of the radiator. Leave the bleeder open till the valve spurts water out, then close it.
Continue this until all the rads are full of water.
If no air or water comes then your "fill Valve" on the boiler may be faulty and not allowing water into your system. You may need to replace that and then bleed the rads.....
Bottom line.... air does no heating, the rads must be full of water to make heat. Air in the rads also air locks that loop in a mono flo system...thus no heat...
Sometimes even after bleeding it can take sometime for the water to start flowing through a rad again... be patient...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 14, 2009 | Heating & Cooling
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
RAds don't get hot anymore
rads not heating could be down to old system ie pipework etc and sludge building up. r there any cold spots on rads? when boiler turning off do u mean going to reset? if so could be over heat prob at boiler . there should be a pressure pipe coming from boiler going to outside if its a combi. if this is leaking your expansion vessel might need re charged as this is where the water will be going.
Feb 05, 2009 | Combi Centre DX - Mango
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
My heating system is a Heat Line Compact gas boiler. When i turn on the boiler to heat the rads the pressure guage goes up to 5 and water comes out of the overflow pipe. Can you tell me what the problem...
Yes, your pressure is too high or your expansion tank is bad or the relief valve is bad. The water is expanding when heated and no place to expand too. I suspect the expansion tank. If you can get to it, tap it with a tip of a screw driver. It should sound hollow.
Sep 18, 2008 | Heating & Cooling
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
