My stereo in my car will get really quiet when i brake. and when i accelerate it will get back to how it is supposed to be. it does not have this problem when idleing, and its only when i have a cd in
    Genius:
  • 1,550 Answers
Check the wires maybe one are put on a wrong site.
Posted on Aug 25, 2008
What could cause flywheel noise on 2004 chevy trailblazer?
Check for loose bolts on the torque converter. Under load the bolts get forced to one side of their hole.
I suppose it is also possible to have the flywheel bolts loose, so if you do not find loose torque converter bolts, keep digging.
Jul 18, 2014 | 2004 Chevrolet TrailBlazer
Tip
Quiet your brake pads
Brake pads can be difficult to keep quiet.I have learned that dressing the brake pads before installation ,saves a lot of time .The brake quiet you use on the back of the brake pad,helps,no doubt.But sometimes,they will still make noise.Why not address the situation before installation of the new brake pads.Now some brake pads come already,what I call tapered.But not all.If you purchase a new set of brake pads,and the pads are squared off at both ends of each brake pad,then you might want to taper the pads yourself.A bench grinder works really well,or a file.Not much has to be took off the ends of the brake pads,but the more that is tapered,the longer the effect last.Grind,or file(using a face mask over your mouth)each end of the brake pad(all brake pads ,4 ) removing the edge from the brake pads.grind it down,tapering it down toward the metal.Now remember,you are tapering the friction side of the brake pad,not the metal side.When you are finished,if you lay the brake pad flat on the metal side,then the ends of the brake pads will be slanted down ,toward the metal.When this is done,it prevents the brake pad edge from causing a vibrating noise,that we all hear as brake squeal.I think you will be pleased at the out come,and do use the caliper lube on the slides ,and the brake quiet on the metal side,this combined together will over come the squeal we all love to hate!
on Dec 01, 2009 | Chevrolet 1500 Cars & Trucks
Steering wheel shakes at times when accelerating and when applying brakes, noise coming from rear wheels
the rotors on your car are probably warped might want to check your sterring links tye rods etc your rear brake noise could be bad rear brakes
Feb 23, 2014 | Metra 40-cr20 2007-2008 Chevy Aveo Ls...
Does a 2002 Chevrolet Impala have C V Joints
Yes it does and it is more than likely what you are hearing.
Nov 29, 2011 | 2002 Chevrolet Impala
2003 Chevy Malibu. The brakes feel really tight, and not the car accelerates by itself. Normally a really quiet engine, but now it sounds like something is about to blow.
Sounds to me like a major vacuum leak if when you say the brakes are tight. Do you mean the pedal is real hard. If this is the case, Your power booser for your brakes are done by vacuum. If you know where your master cylinder is (where you put the brake fluid), the master cylinder is bolted to is the brake power booster. If you look at the picture below it will kind of look like that (the one in the picture is from a Nissan but looks the same). You can see in the picture on the top left of the unit is a inlet going in. That is where a major vacuum line goes. Check that line from the booster to where it attaches to the engine. Make sure it is connected and without holes and stuff in it. The reason I feel this may be your problem (and i may be way off) is that you say it accelerates by itself and sounds like it's gonna blow. To me the sound could be the air you hear leaking and the car accelerating by itself could be due to high idle because of a vacuum leak. the booster itself could be leaking as well as it has a diaphram in it that could break and cause a vacuum leak and you would hear it as well. I hope I am on the right path for you and can only go by what I am reading and that is what it sounds like to me. I hope this helped and good luck. Here is the picture:
Feb 25, 2011 | 2003 Chevrolet Malibu
Squeeky brakes
how bad do they squeak, is this after a recent brake job? minor squeak is normal and doesn't affect the performance of the brakes, u can apply a product call "brake quiet" to the back of the disk brake pads, it really works, contact Napa auto parts to buy this.
Sep 22, 2010 | 1996 Isuzu Oasis
Humming/buzzing in aftermarket stereo when accelerating vehicle.
i once installed spark plug resistors (arrestors) that are supposed to help
Nov 06, 2009 | RCA Pac Sni1 Rca Ground Loop Noise...
Aux (RCA cable)
you have to make sure its and input aux first
Jun 24, 2009 | Panasonic CQ-C8300N CD Player
I have a 2003 Santa Fe (approx 71K miles - new brakes in March 2007) that has been making a low pitch sort of squeal when I am accelerating between 15 mph to 40 mph. Getting more frequent and sometimes at...
Either the caliper pins are not releasing properly(cleaning and lub. will solve that) thus causing brake pads to partially stay in contact with your brake disc(rotor)
or its possible that your brake discs have exessive riges on the outer ege(if spec. allows discs can be skimmed or replaced)
also try shamferring the brake pad eges and remove forreign dust/dirt particles from and arround your calipers.
Jul 23, 2008 | Hyundai Santa Fe Cars & Trucks
18 people viewed this question
 Grubhead
Grubhead
