Ricoh Aficio 6513 Black TOner not set
I have cleaned all sensors, reflectors and blow the copier and replace toner cartridge but still have the problem of BLACK TONER NOT SET. Can any ont please help me out what else to do?
thx,
Dino
  • Anonymous Mar 02, 2009
Clean the toner cartiage reflection mirror, and, the sensor behind the rota cotains the 4 colour toner
Posted on Nov 03, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Double check the developper, vacuum the top and make sure there is no previous cover from the last toner, it goes in and connects ok, the switch is ok.
you sound like a tech there must be a service mode to check the sensors, look at the sensor for the toner and check if it changes
Posted on Aug 27, 2008
Price of print cartridge
Depending on the vendor, you can get the Ricoh 406464 toner for the Aficio SP 3410SF (regular cartridge, not the high yield one) for between $65 and $90 . Some sites to look at http://www.bluedogink.com/ricoh-406464.html and http://www.staples.com/Ricoh-406464-Black-Toner-Cartridge/product_332848 .
I hope this helps.
Sep 15, 2011 | Ricoh Aficio SP 3410SF Laser Multifunction...
Sc 400 code ricoh c221
An sc400 error means the toner mark sensor needs to be cleaned. Cleaning this sensor is easy:
Open the top cover and remove the cyan toner cartridge. You'll see a long black lever with a sort of handle that pokes upward -- slide this lever ONCE to the left, and then it should slide back into place.
Now replace the cyan cartridge and close the cover, and your printer should be fine. (If the error doesn't clear, turn the printer off and back on and it should go away.)
Aug 19, 2010 | Ricoh SP C221SF Aficio Printer
Toner cartridge not loading
Cheat the front door interlock and watch the toner bottle to see if it is turning. If not, could be a bad toner drive motor/drive assembly. Otherwise, remove and disassemble the toner hopper and clean it up. Make sure the four clear 'scooper' tabs are attached on the back of the receptacle that fits around the top of the toner bottle. Otherwise, just purchase a new toner hopper, they are cheap.
Sep 15, 2009 | Ricoh Aficio MP 2000 Black and White...
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Replacing toner
Check the developer.
Jun 17, 2008 | Ricoh Aficio 250 Copier
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Oct 17, 2007 | Ricoh 6513 Copier
Error code
sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Sep 05, 2007 | Ricoh 6513 Copier
102 people viewed this question
k24674
jasbo
jasbo
