Question about Hotpoint RGB745 Gas Kitchen Range
Oven not heating(magic chef
My oven takes sometime an hour for the gas in the oven to catch. I continue to push and turn the temperature knob to 500- as of yesterday it wouldn't heat at all...any suggestions
I live in Japan. I got a brand new range in june and it has had this problem from day one. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Posted on Sep 12, 2008
  • 1,543 Answers
Sure. If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often.
Posted on Sep 01, 2008
Oven takes too long to heat up sometimes wont even go to the temperature ignitor is working well can see the glow magic chef model 3488vvv serial 13368882kz
Hello there:
When you turn the oven on, open the oven door and look down at the bottom and see if its glowing red, it should glow red for about 45-60 seconds then you should hear the gas ignite. If the gas doesn't ignite, then your igniter glow bar is bad.
Here's the oven glow bar igniter for your model:
Manufacturer's Number: 74007498
Sep 28, 2010 | Ovens
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
The oven takes a long time to ignite. Sometimes
Hi, sounds like a weak igniter, you just need to replace it.
Jan 14, 2010 | Magic Chef CGR1425 Gas Kitchen Range
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Fan in oven will not shut off, F-4
Hi jsachse,
The F4 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Dec 18, 2008 | Magic Chef 31000 Gas Kitchen Range
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Feb 26, 2008 | Kitchen Ranges
Oven wont regulate temp
is your temp control operated by a knob or push button?
Nov 22, 2007 | Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range Logo
183 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
