Ws-65613 tv trouble shooting
Hello
this tv is blinking green light constantly
wont power turn on key switch dosent work
can you find it please contact us
thank you
myong west
  • 2 more comments
  • myong west Aug 25, 2008
    power switch & reset button dosent work
    we need more information
  • myong west Aug 27, 2008
    1.standy power supply
    d9a13 9vs ok
    d9a30 12vs ok
    d9a33 6vs ok
    but main power supply dosent work
    pon-2 do not come in q9a51 base from micom
    we need next soluton
    you can find it please contact us
    thank you
    myong west
    horizontal tr is ok & we chaned new converzence ic but main power supply dosent work
    we need next step solution
    thank you
    myong
    power switch pulse come to micom but dose not come out pon-2 pulse from mocom
    we need next solution
    thank you
    myong
    Master:
  • 763 Answers
It should be work by an expert technician with a tools and some spare parts. if your tv is on warranty send it back for their service.
CHARCOIS
Posted on Aug 27, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
It is problem with DM module board. Check the board......
The service manual as well as the documents to repair the DM board are on their way. Just remember to be careful with the printed circuit board in this TV set. If you do not know how to solder, take the board to someone who does, as I have seen loads of boards that could have been repaired, but because of poor solder skills, the boards were trashed. Good Luck with this repair and let us know how you make out with this repair.
thanks
good luck
    Genius:
  • 2,920 Answers
Replace the power supply
  • 2,326 Answers
Click here to find detailed information about the failure on your TV. From this point forward you will now if you can fix it yourself or find a repair tech to do it.
Check all the links from the thread to see how is done. You TV model number only has 4 capacitors in the DM board.
Let me know if you need further assistance.
Posted on Aug 25, 2008
    Genius:
  • 1,269 Answers
The switch itself maybe burned, loose or shorted. That one needs replacement. If you have no idea how to do it, it's better to contact repair technician or bring your tv to any service center
  • 10,594 Answers
Your TV has shorted Horizontal Output Transistor or it has faulty convergence ICs, so blinks error.
Let me know if you know electronics repair, to help you more.
  • 6,487 Answers
Could be poor solder connections, the power coming to the DM board from the main power supply could be bad, the eeprom could be bad, the power supply or sweep power supply could have bad connections or swollen capacitors.
First thing to do is to check all of the plugs, connectors, and connections to and around the DM board. Next would be to check for other large capacitors on other boards with swollen tops. The next thing would be to start checking power supply upon switch on. I'm afraid you will need to call in a tech to assist you with this repair.
Hope that helps.....
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Aug 25, 2008
    The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
  • LORETO LACARON
  • LORETO LACARON
    You must do some checks first:LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds . LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001.
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Can't turn on the TV. Green light keeps blinking.
You need to change the four capacitors C9B01,C9B02,C9B10,C9B11 all 1000 MFD 16 VOLT (on the DM board which is inside the metal shield standing upright on the left looking from the back of the set)The tops of the capacitors will look puffed out making them easy to find. This is your HD tuner digital board which is trying to reboot but can't - when the green light stops blinking after a minute,than you can power on your TV.
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
WS 65613 MITSUBISHI
your problem is in the power supply.check the regulator
Nov 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light and tv would turn on
blinking light is an error code. Check the manual for it's meaning.
Aug 14, 2008 | Mitsubishi WS-65613 65" Rear Projection...
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
Jun 30, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 blinking green light
Try doing the self test by pressing input/device and menu for 5 sec. You should get an error code by blinks. see ctechnicians.com
Dec 30, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65613 65 in. Rear
Bad DM module = replace or repair by skilled Mits tech only....
Research my solutions or comment,please.....
Oct 17, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Ws 55513
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
