Question about HP Pavilion dv2000t Notebook
Fix the svchost.exe
I m new to the internet my computer giving the error msg that svchost has infected it
    Scholar:
  • 133 Answers
You **might** be infected with spyware that a regular cleaner cannot pickup.
I reccomend you find a utility called "HiJack This!" and use it under the professional care of someone who is skilled to read out your scan from the utility and tell you what to repair. Unfortunately , I am not one of those qualified to read the logs and give advice.
Posted on Aug 25, 2008
Svchost.exe-drive not ready
svchost.exe-drive not ready
Jun 01, 2011 | Computers & Internet
Application popup: svchost.exe - Application Error : The instruction at "0x745f2780" referenced memory at "0x00000070". The memory could not be "read". Help me to rectify this...
this is a common error if you try to install a new memory card or if you are infected by a virus. if you tried to install/upgraded a new memory card. these are the thing you need to consider - memory card is not properly installed to the memory slot - memory card is not compatible to the system - if you added a new memory card it means that there is a conflict between the old and new memory card
if you did not install/upgraded a new memory card. these are the things you need to consider - you are infected by a worm/virus. try updating your system by installing system updates. install antivirus software - you might install a software that is having an issue with the memory installed in your system. - Operating system is corrupted need to reinstall the OS. - hardware failure try to check first the memory card then hard disk. or just contact local technician.
May 09, 2011 | Intel Computers & Internet
I'm receiving 2 messages from my webroot internet security essent
This sounds like a virus to me? you say you are receiving that message, please, is it Windows "Telling" you?, or some program "Telling" you? please clarify? svchost, is not something that should be deleting anything...Both TCIP & netbt are VERY important part of Windows, so I do NOT think, it should be allowed.
Feb 28, 2010 | Webroot Internet Essentials (83210)
BSNL net connects but after some time svchost.exe error occurs
The problem is with the Windows operating system. Either the OS is infected by a virus or it is corrupt.
The best and effective thing I can suggest you is to reinstall the Operating system on the computer. Please scan your computer once you have reinstalled the OS using a good antivirus.
Hope this helps.
Jan 12, 2010 | Microsoft Windows XP Professional
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Svchost error memmory
Svchost.exe acts as a host for a group of services on your computer. As you are aware there a many services and programs the run silently in the back ground. Svchost.exe pools many of these services in one group and runs all at the same time. This is a great for efficiency. However, it can cause your CPU to spike to 100%.
As mentioned before svchost.exe is essential. So the trick is not to block svchost.exe, its to limit your computers need to use it. You can limit your computer need for svchost.exe. By cutting down on the services that are loaded when you PC starts. This can be done quite easily.
1. Open your Start menu.
2. Click Run
3. In the command screen type: msconfig
4. In the "system configuration utility", Click "services" tab
5. Uncheck all services that are unnecessary.
6. Click "OK"
Uncheck the suspecious services but make sure you do not stop necessary services. Restart the PC to take them affect
Mar 20, 2009 | Dell Inspiron B130 Notebook
Svchost.exe problem
i think its a virus or a worm problem to get rid of this go to my blog and download quickheal two months full verion scan it will clear your problem
dont forget to turn off system restore before installing and upto completing the complete scan of your pc
bye bye
http://xviruslab.blogspot.com
Feb 28, 2009 | Microsoft Windows XP Professional
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
Svchost virus
u can change antivirus i suggest u can install norton antivirus 2007
Mar 07, 2008 | Computers & Internet
Svchost.exe
svchost.exe is apart of windows. It sounds like your system was infected. When you install security on a system thats not healthy, the infection can compromise and corrupt your new security causing it to not work correctly, or show false positives.
Mcafee and CA both aren't that great. I recommend the paid edition of Malwarebytes and AVG. Both work much better then CA, Mcafee, Norton, etc.. just to name a few.
At this point your going to need to get the system healthy. This is the dangerous part I recommend letting a professional help you, because remvoing infections can cause data loss and you risk making the system even worse. I recommend NickLockard.com
http://www.nicklockard.com
Nov 16, 2007 | Sony Ericsson K608i Cellular Phone
HP Pavilion dv2000t Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
