Question about Sony DRU-710A DVD±RW Dual Layer Burner
Power caliberation error
Hi ,
I seem to be having a problem while burning dvd,s. The error that pops up is power caliberation error. I tried writing at lower speeds but in vain. can you suggest something
    Sergeant:
    Novelist:
  • 192 Answers
Try uninstalling your burning software and then re-installing it.
Try uninstalling your drive, restart, and let Windows install it.
Download and update your Chipset drivers (recommended)
Update to the latest Windows Service Pack (recommended)
Uodate the drives Firmware version and internal drivers:
http://sony.storagesupport.com/product/112#drivers
Hope this solves your problem
Regards,
Tim
Posted on Dec 10, 2008
HP Dvd1260i Internal Dvd-writer -Dvd-ram/r/rw not writing ,but reads,plays music. Pl. solve the problem (please)!
No PC stated
why post lacking what operating system is there,? too.
no burn software stated. (app)
try imgburn, free, it works like gang busters.
what cant it be?, well lots !
1: bad dvd drive.
2: bad disks, DVD-r works best. or CD-R
3: bad burn program.
4: infected OS, gee if XP its sure is, all are now. its a virus magnet.
5: bad dvd drivers. (if XP?, need sP3 first and then needs the HP drivers, then needs the registry filters cleaned. (all pain here, take great skills to make XP work, and lots of text in a box, endless.
(to solve any problem like this,
replace it is most easy first or most cheaper.
your call that.
yet on more post lacking and OS. (par here)
Dec 06, 2017 | HP Dvd1260i Internal Dvd-writer -...
My computer burns dc fine but does not want to burn dvd, I get error message tellimh me that there has been a problem at the very beginning of the burning process. The disks are then unusable. What can...
Hello leslaw176,
Your problem in your burning of DVD will be solve by just using other burning application like Nero DVD burner (which is the most stable and user-friendly software) software and by lowering your burning speed. There's an drop down menu before you burn you DVD which tells you what speed will be using try 16x in DVD. Its better to write normally than writing in full burst.
May my solution may solve your problem.
Thanks for using Fixya...;-)
Aug 19, 2011 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
  • Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
  • Try burning at lower speeds (Highly effective).
    Disable IMAPI Service (Work's in most cases):
    1. Launch Control Panel -> Administrative Tools -> Services .
    2. Browse for "IMAPI CD-Burning COM Service", Right-click on it and select properties.
    3. Chnage Startup Type to Disabled.
    5. Click Apply and Reboot.
  • Try updating or changing your CD\DVD burning software to the latest version.
  • Try upgrading your writer's firmware.
  • If all the above fails the problem is definitely related to hardware and not software, Go ahead and get your burner laser lens cleaned by a professional.
  • If all the above fails the drive's laser might have died and you need to get it replaced.
  • Best Of Luck, do post your results.
Jan 16, 2011 | Computers & Internet
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
I only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Sep 06, 2009 | NEC ND-2500A DVD±RW Burner
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
Hp burner 630
Can you specify what these particular errors in question are? Assuming that these are read/write speed errors, changing the write speed settings to the slowest speed is your best option and is usually recommended for CD/DVD Authoring for less write errors.
May 16, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
Samsung SH203N
well you could try to set it to the right speed and then maybe you never no it could actually work and you would get more custmers.
Apr 07, 2008 | Computers & Internet
DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Feb 28, 2007 | Sony DRU-820A DVD RW Dual Layer Burner
Sony DRU-710A DVD±RW Dual Layer Burner Logo
121 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
