Question about Insignia NS-DA2G MP3 Player
Can not delete tracks
I use real player to transfer all of my music to my mp3, the mp3 itself says i have 118 tracks however only 56 of them show up on my computer...i have songs i want to delete to allow more space for new songs...but i cant get rid of them
  • tweek_2k Nov 27, 2008
    I've got about 110 songs on my NS-DA2G and only 12 show up on Windows Media Player. How can I get them to register?
How to upload musci from LIME WIRE to my Insignia
Posted on Nov 07, 2008
The tracks all say bad track and will not play, how do I fix the problem?
These tracks are corrupt Delete all Format
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Try and drag and drop2.gif from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Oct 24, 2009 | SanDisk Sansa e260 MP3 Player
Cannot transfer from MP3 player to PC
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier
May 30, 2009 | SanDisk Sansa e260 MP3 Player
Can't delete duplicate tracks!
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Apr 17, 2009 | SanDisk Sansa E280 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
When i transfer music from my library it deletes all existing tracks from device
Are the existing tracks still on your computer? Most mp3 devices won't keep existing music on the device unless told to do so. Basically, don't delete any playlists or tracks from the program that you are using to transfer the music.
Jun 30, 2008 | Audio Players & Recorders
Deleting the same song, with a different name
the reason it doesn't show the track version is because you changed the ID3 tag (which is something inside the music file, not the actual file name).
Try using winamp to delete your songs, it will read all the ID3 tags properly and show you the track version names
Sandisk provides "how-to" videos for everything Sansa related
http://www.sandisk.com/Retail/Default.aspx?CatID=1468
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
Copied tracks
The device hes 2 modes.
If you transfer music in 1 mode, you cannot see it on the computer in the other mode.
Change the mode on the device Settings>Mode or USB Mode.
You should see the same tracks that are on your device. Delete the music from ! mode and your problem will be solved.
Best of Luck.
Oct 11, 2007 | SanDisk Sansa e250 MP3 Player
Deleting Music Off of The mp3 Player
when you open the mp3 player up in my computer and look in the folders, in the open window go to folders, files at the top, view and then look for show hidden files and tick the radio button, it should then show all the tracks.
Sep 26, 2007 | RCA S1000 MP3 Player
RCA Lyra RD2763 5 GB MP3 player
You have to subscribe to be able to play any tracks downloaded from URGE or REAL or anyplace like that. Once the trial is up you have to pay to be able to hear them. I found out after spending days filling my player full of music. I ended up deleting all and transferring tracks from CD's or actually paying to download tracks.
Mar 02, 2007 | RCA Lyra RD2763 MP3 Player
I can't delete Some files
I've had this happen too--you gotta be in MTP mode to really take advantage of the true ease-of-use of this little gem. The solution here is to physically delete the file from the player on your desktop. If you can't delete the file there then you might have to reset the factory settings (eek). Also, if an mp3 track doesn't have a title (or a filename), it will show up as "Unknown" on the player and it will not play. You have to physically give the file a name by dragging it to your PC desktop, naming it ("properties") and then copying it back. It forces you to keep a clean music library for sure! FYI: Trying to do stuff in MTC mode I've found to be a real pain (and, no, you DON'T have to be use MediaPlayer to transfer mp3 songs, albums, and playlists--drag-and-drop works in both modes). Use MTP mode for the real experience.
Dec 11, 2006 | SanDisk Sansa e250 MP3 Player
Insignia NS-DA2G MP3 Player Logo
87 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
