Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Control Panel Installation
I want to replace the control panel on our Bosch WFMC6400UC washer. In order to do that I have to seperate the user control knob from the control panel. I expected to be able to pry the knob out of its socket but have been unable to do that. Is there some trick to removing the user control knob?
  • 1 more comment
  • johnmargieV Aug 28, 2008
    I have tried pulling the knob off and using a screwdriver to help. Neither of these methods have worked. What else can I do?
  • johnmargieV Aug 29, 2008
  • johnmargieV Sep 04, 2008
    The control knop is an integral part of the top panel that is visible to the operator. The solution is to remove the control panel using the clips on its sides and two detents that can be accessed through square holes in the control panel which are located near the end away from the control knob. Upon removing the control panel, the control knob slips out of its design position. while replaceing the control panel insure that the control knob is in the correct rotational position.
    Neither of the solution offered will work.
    Genius:
  • 1,665 Answers
Insert model number at search tab of link below to see parts details
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Sep 04, 2008
    President:
  • 1,952 Answers
Epending on the model that you have, you can put it into a self diagnostic test mode that will tell you the fault code (problem) with your machine.
Posted on Aug 29, 2008
    Master:
  • 521 Answers
Dont try anything unusual as it will cause damage to ur unit.i am sending u the link with complete details to replace the parts of the washer step by step.:
http://www.applianceaid.com/washers.html
pls do rate the solution
thanks.
regards.
fixya expert team
    Genius:
  • 1,011 Answers
Dear Sir/madam,
If you are not comfortable doing the job yourself, then get a technician to help. It is not too bad at all....and most can do it.
If you do want to attempt it....unplug the machine....first pull the knob off the front then remove the back of the console...there should be about 8 to 10 screws holding it on, removing the panel will expose the switch...it may be identified by the hose attached to it.
There will be 2 screws holding the switch in place, remove the screws and the small hose that attaches to it, once that is removed, replace it and transfer the wires and the small hose.
re install the knob, and the back of the console.
Plug the machine back in and test your repair...
thanks
good luck
    President:
  • 1,263 Answers
In some instances there is either a set screw(generally a small allen head) or a small pin that has to be forced out. these keep the knob from spinning on the shaft and stripping it.
  • 446 Answers
This is force fit knob, just pull that right up and it wil get loosed by itself, or you can use a negative screw driver to help a bit
cheers
Posted on Aug 25, 2008
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
Mar 26, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have an Bosch washing machine, model WFMC6400UC 12391301. I get the drain blocked Fault notice on the control panel.I have opened the cover and observed the pump working, I have blown out the discharge...
Bosch washing machine, model WFMC6400UC 12391301 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 31, 2011 | Bosch Nexxt300 WFMC220 Front Load Washer
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
How do i open this unit?
Remove control panel to gain access to screws and remove door boot and tilt forward this should give access
Jan 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Control panel went to german
Maybe you could try unplugging from power source for a while. Perhaps it will revert back to original settings i.e. English. Also, sometimes there is a 'reset' button on the telephone. If you don't have a copy of your manual, look online at the company's website for it. Hope this helps but it is worth a shot anyway!
Jan 02, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC does not start with the following status: Start/Paus light blinking Display says ready Pressing start does not do anything I have done the following: Holiding the Start...
A faulty module or timer/control panel. Unless you are getting some form of error code in the way of flashing lights or otherwise. In which case refer to manual. Good luck.
Sep 07, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
No LCD Display
they can fail try writing a letter to the manufacturer,if there a good company the will help.
Feb 11, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Computer defunct
1. Try unplugging the washer power cord from the wall for 5 minutes and then plug it back in. See if this helps the problem. This will give the computer module an opportunity to reset itself. You may have to set the clock when you restart it.
2. This washer has a two year parts warranty. Find your original receipt and see if you are in warranty. If you are, find a Bosch warranty service provider here. I don't think Sears is Bosch authorized.
http://www.boschappliances.com/site_tools/Servicer_Locator1.aspx?menu_id=1&menulevel=02
There are several models of the Premium washer. This is the control panel that fits mine. Yours should be similar in cost.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094534&PPStack=1
Jan 16, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
252 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
