Power problem if power is cut suddenly unsaved dates are deleted. I want create a editor in vb that save whatever typed in textbox.pls give me a solution for this problem
  • 66 Answers
Hi, you can just save it more regulary?
 there is a powerbox (uninterruptible power supply units) which give you a extra time to save your work and turn off the computer (they are expensive but if your work is important this is the way to go)
hope this helps :-)
Posted on Sep 03, 2008
My program file regsvr.exe delete.How restore this
Dear Amartya,
Here is a solution for your problem.
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. Read this post to know how to do that.
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon and modify the entry Shell = "Explorer.exe regsvr.exe" to delete the regsvr.exe from it.
I think it helps.Let me know
Best regards
Chandrashekahr Bhat
Dec 25, 2010 | Microsoft Windows XP Professional
How to change a date in a picture file created by a kodak cx6330 camera
Depends which date.
 - The file date can be done by resetting the computer date, opening the file, saving it as something else, change the computer back, delete the old file and rename the "save as" file.
 - If you mean the date in the EXIF data, you need an EXIF editor - Google for PhotoME.
Jan 06, 2010 | Kodak EasyShare CX6330 Digital Camera
My laptop was makingh some updates last night but
Dear,
Have you saved any part of that docs any where in you pc, than you can retrive it with a ~ befor the file name.
If did not saved it at all you can see this in C:\Windows\Temp directory with ~ in file name.Best of luck
Oct 16, 2009 | Acer Aspire 5050 5430 Laptop
Computer cannot restart and i fear i will lose
Hi there
The delete restoration data indicated the system has gone into hibernate mode. If you had any unsaved Word documents open on the screen before it went into hibernate mode, only the unsaved changes will be lost. The actual documents (if previously saved) will remain saved.
You can safely accept the delete restoration message, and the system will boot as normal and let you login. As long as your current work was saved, it will stay saved.
I hope this helps. Kindly rate my solution if I have been helpful.
Thank you.
Aug 23, 2009 | Samsung NC10-14GW Notebook
How to create Dynamic Lable & TextBox & save their Values in DB.
Best way to do this is to place label and textbox as usual but hide them from the properties.
In the SaveButton Click event, you can set the property for the label and textbox to visible dynamically by code.
Apr 24, 2009 | Microsoft Designing ASP.NET Applications...
Microsoft Access query in VB
first you need to create a record set to do this, after creating a record set RS1. please follow the code below:
Update the code as per your requirement.
Rs1.Open "Select * from table_name where UserName = '" & UName & "'", Cn1, adOpenDynamic, adLockOptimistic
Mar 14, 2009 | Microsoft Visual Basic 6.0 for PC
How to create a Computer aided instruction system using VB
if you have some knowledge about VBasic you can create simple programs using label,textbox,progress bar,combo box use your logic to make it beautiful..
Jan 21, 2009 | Microsoft Visual Basic Professional...
Program not working
Type mismatch is caused by trying to use a variable defeined as one type to store another type of data. For example a variable that is integer but you try to set it to a letter.
In VB.net this can be caused by a line like this:
textbox="hello"
when it should be
textbox.text="hello"
see if you have that sort of mistake.
Dec 12, 2008 | Microsoft Visual Basic 6.0 for PC
Vb code for automatic number change
You want the code for when you press enter in textbox it automatically change to 1.
I am typing C# code you can easly covert it to VB.Net code
make an event for key press for textbox
and write the followting code in the event
IF textbox1.text = ""
textbox1.text = "1"
End IF
I hope your problem will solve with this If need more assistance let me know. If your problem is solved then don't forget to make answer my thread.
Regards
Nov 17, 2008 | Computers & Internet
Visual Basic 6.0
1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to, image editing software, text editor and database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
Feb 20, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
