Question about QSC MX1500A 2-Channel Amplifier
INSTALLING TO MY HOME THEATER SURROUND SOUND
HI CAN I CONNECT THIS AMP TO MY HOMETHATER SURROUND SOUND
  • Marc Wiggins
    Marc Wiggins May 11, 2010
    yes, you can. the questions are what do you intend for this amp to drive?(speaker ratings,and make model) and what kind of pre-amp/receiver are you planning to send the signal?This is a pro amp,got one in my HT system and can't go above 20% without angering eveyone in the house, not to mention nearby neighbors.
  • Power Electronics
    Power Electronics Nov 08, 2013
    Adding a comment to Marc, you will need a big power speakers to drive safely with such powerful amplifier, good luck with your project.
    Champion:
  • 243 Answers
Adding a comment to Marc, you will need a big power speakers to drive safely with such powerful amplifier, good luck with your project. Nov 08, 2013
Posted on Nov 08, 2013
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Install Pioneer surround sound
easy look at the back and treat the holes like a tap water comes out the tap into the drain treat the drain like your amp so what I'm saying connect you tv etc to the inputs of the amp and most people don't need to worry about the out puts on the amp and from the tv or dvd player you need to connect the cable from the out put to the input on the amp :)
Jan 30, 2014 | Pioneer Dolby Digital 5.1, Pro Logic II...
Samsung Surround Sound & Palsonic TV = no surround sound on TV
Do you have an optical audio output jack on your tv? Some tv's don't output audio from that jack unless you go into the setup menu and turn in on.
Jul 18, 2013 | Samsung Ht-e5500w 2d 3-d Blu Ray Home...
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
How can i hook up surround sound to cable box and ps3
The easiest way will be to connect your PS3 and cable box to the TV by HDMI and then run an optical cable from your TV to the surround sound system.
Regards,
sjstore2
Dec 19, 2010 | LG LHT854 Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
Open Questions:
See all QSC MX1500A 2-Channel Amplifier Questions
QSC MX1500A 2-Channel Amplifier Logo
141 people viewed this question
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
