Find the codes andm menue for remote uRC3605B00 remote control
How to program the oneforall remote controlto as sanyo tv ? codes for remote # urc4605b01 for sanyo tv
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): Find the codes andm menue for remote uRC3605B00 re - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I bought a oneforall universal remote but need a code for a supersonic 1380
If you are a user of AT&T Uverse remote, your technician might have possibly programmed your Sanyo TV remote before leaving.
If your remote is not programmed you can easily program it by following steps which will be mentioned in the user guide, these include:
  • You must know the four digit code for AT&T Uverse which might have been given to you at the time of TV set up.
  • The remote control codes for Sanyo TV AVM - 1337U are 1045, 4062, 1095, and 1380.
There are different methods to make your Sanyo TV remote work. For example, if you have a black remote, press the zoom button which will be on the right hand corner of your TV. Then you will have to press fast forward for two seconds or till the time the TV shuts down automatically. Then once again switch on the TV and press zoom, your remote will start working once again.
In case you have a silver colored remote control, enter code 922, you will be guided to a menu. You must select RCA. IF code 922 does not work for you, enter code 1041.
  • Any of the codes mentioned in your user guide book will definitely work. Once the code is accepted by the TV, you can program it easily and set the channels of your choice.
  • While setting programs you can program it either the manual programming method or the code search method.
  • Device codes assigned to the TV will again be mentioned in the user guide booklet.
  • The Uverse remote control is a universal remote control which is user friendly.
  • These programmed remotes are configured to work with other audio and video devices too. Uverse also offers other services such as high speed Internet, cable TV service, home phone, etc. It's rated as the best service provider in the market.
Audi Air Intakes
Jun 07, 2012 | GE Televison & Video
Code for tv sanyo
Try TV Sanyo 0154
The manual and the code list are available here: http://www.oneforall-na.com/remote.php?type=URC%203021 .
Please note that if the codes in the remote are usually limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps.
Mar 22, 2011 | One For All URC-3021 Remote Control
Cant use my oneforall remote w/ out sony tv code
http://www.remotecentral.com/cgi-bin/codes/sanyo/
May 30, 2010 | One For All URC-3300 Remote Control
Need codes for a oneforall URC-3220 apex tv sanyo vcr
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Sep 21, 2009 | RCA Universal Remote Control
Need code for sanyo tv (oneforall remote control)
google ..."oneforall remote codes".... there is a site with all the remote codes for most types of oneforall remote controls and even an archive section for older models. follow the instructions and it will lead you to the proper codes. i have used the site several time with great success.
good luck , jay
Mar 21, 2009 | Sanyo Televison & Video
Trying to get a code for my remote control
do you have the page that came with the remote
Mar 18, 2009 | One For All URC-3021 Remote Control
URC3220 remote problem
i have a sanyo tv i need the codes to program it and directions with the allforone...urc3220 remote ty ron t.
Apr 27, 2008 | One For All URC4110 Remote Control
Televison & Video Logo
440 people viewed this question
Top Televison & Video Experts
Electro Med Services...
