Question about Durabrand Anti-Skip CD-895 Personal CD Player
Volume control when I turn on my player it automatically starts at volume 17 even if I have it set at 5 why so loud???
  • 3 more comments
  • sscrogham Aug 29, 2008
    I use this product as my alarm...why must the sound always come on at 17. This is very loud! Is there any way to fix this??
  • katiejohnson Sep 09, 2008
    Is there any way to change the volume level when it comes on???
  • kmullins53 Oct 02, 2008
    Volume always goes back to 17 - way too loud!
  • Anonymous Dec 30, 2008
    The volume won't stay lower then 17 when the alarm comes on
  • kencolpat May 11, 2010
    Has anyone found a solution to the high volume on start up?
The only thing I have found that helps is to change the function before turning it off. Then when it comes on, turn the volume down before changing it back to radio. It's not a fix, but at least the radio won't blast on. It's very annoying!
Posted on Oct 03, 2008
Not yet
My RX-V567 (about 3 months old) has some problem with the sound output. Sometimes when it is turned on, it gets very loud even though the volume is set at around -48 db. And when I turn down the volume, it...
Your volume control is not tracking properly. Might want to clean out the control chemically.
Check the surround on the subwoofer speaker. If it has self destructed the surround needs to be replaced.
Sep 03, 2017 | Yamaha RXV567 Receiver
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
How to set start up volume control
I read another post that says that if turn on the unit and set the volume where you want it at startup, and then press in the volume knob until you hear it beep, that locks in the current volume as the startup volume. I just read this, so I haven't tried it myself yet. Good luck!
Apr 12, 2009 | Jensen VM9510 Car DVD Player
Volume problem
the code should be one the back of the ipod
Oct 25, 2008 | Apple iPod nano
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Volume not loud enough
Actually there is a way. If you re-encode the file using an mp3 conversion utility, you can adjust the volume there
Jan 19, 2008 | Philips GoGear SA178 MP3 Player
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
