Question about Protron PLTV-32 Television
Power Supply I checked the ceramic fuse after the switch assembly and that was fine. The I/O switch itself was tested to be ok also. Everything I'm reading points to the power supply? Is this correct and if so, where can I order one for Protron??
  • dculican Aug 25, 2008
    I was being honest, thank you for trying...I did not know they were bankrupt.... It isn't helpful to me, because it does not solve my problem..... if you said, they are out of business but you might want to try company xyz, then I would say that is helpful.... once again, thanks for trying
I had a pwer supply for my Protron 32 inch TV that was not working. I bought the one on ebay and it stopped working after only three weeks. Ultimately I found a guy who could fix my original power supply for a reasonable price. It been working for a year now with no problems. I wish I would have tried him first!!!! If anyone is interested his email is dave@thola.com.
Posted on Aug 26, 2008
    Sergeant:
  • 359 Answers
Proton has declared bankrupcy and is no longer issueing, honoring, or providing service in anyway shape or form. People that have sent in their TV for service will be lucky to get the broken TV back.
The old saying you are SOL seems to apply here.
Posted on Aug 25, 2008
  • Daniel Jenkins
    Daniel Jenkins Aug 25, 2008
    The rating thanks for trying is not accurate. Please rerate this or I will report this as abuse. Protron is out of business and has declared bankrupcy. What more do you want?
Lg wf 760
please follow the steps and fix it. God bless you
her won't start, the user control and display board may be defective. Check for power to the washer first.
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
May 28, 2013 | Washing Machines
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
test the following steps and fix it. God bless you
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Jan 23, 2013 | AEG Lavamat 12710 Front Load Washer /...
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
It jus stopped working as soon as i set the timer to 3mins jus light switched on for a second and its gone,,,i checked the power output in the plug point its fine...no burning smell and all...this oven is...
in most cases the reason for microwaves shutting down without warning is the fuse. in some cases the fuse will fail at its own fault. to test the fault we would do a tollerence test on the unit. but the best way for you to test it is to replace the ceramic fuse with another of the same value. if the unit works then its a faulty fuse. if the unit blows the fuse then the unit has a fault in the power supply that needs to be repaired by a service tech.
Aug 03, 2010 | LG Microwave Ovens
I have no brake lights or turn signals on my 95 gmc truck. I have replaced the boards but no luck. Also have checked fuses.
OK if the fuses are good , use a test light and check to be sure you have power at the fuse terminals. you'll check from ground to the terminal on top of the fuse. you should have 12vdc. then , check for power at your brake light switch on both terminals while the brake pedal is pressed, it is located located on the brake pedal assembly. also , check your hazard flasher switch to be sure it is not on. if it was on, check your flashers, both the turn signal and hazard flasher. If everything checks out , your problem is probably in your turn signal switch assembly located in your steering column.
Mar 14, 2010 | 1995 GMC Sierra
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
