Question about Samsung Office Equipment & Supplies
Error code jam 2displays after removing paper jam. Samsung printer SCX 4100
    Guru:
  • 859 Answers
Ross,
You have had several excellent solutions brought forward in your premium post, especially to look for little pieces of paper that interfere with the LED lights and the light sensor for that area that sends a paper clear or paper occupied signal to the printer.
When this type of issue arises it is normally after the normal term of life the engineers who designed the printer expect from the printer. Most all rollers have sleeve bearings on either end and these bushings become eccentric vs. round after a predictable amount of print jobs. When these holes do become eccentric one side of the roller turns slightly faster than the other that actually has difficulty keeping up with the other end of the roller. This will cause paper to feed at an angle through the paper path.
Ultimately this leads to a paper jam. Once you begin to have one jam, here and there, you eventually have jams more and more often. When this occurs and actually prior to this series of events, the printer has reached its end of life expectancy. This is a value expressed in pages printed per month or months of service where the engineers expect so many pages per day to be printed. This whole design and life expectancy is exactly the same for copiers and why Xerox, for example, has to come on site at the job or library and do a system overhaul. These overhauls are a replacement of bushings and belts used within the power train.
What this all means is that your printer is either outside its life expectancy and probably its warranty as well.
If you are still in warranty, don't mess around trying to find a band-aid fix for this problem and have it serviced under warranty. You'll receive a refurbished machine in return. This is the best way to proceed. If you are out of warranty and like the machine get a refurbished one.
So, to repeat:
a. Look for small pieces of paper that could be blocking the light sensors and sending a paper jam signal to the printers CPU.
b. If you are out of warranty get a new printer or refurbished one.
c. If you are in warranty get it replaced under warranty for a refurbished model.
Regards,
Worldvet
Any questions? Please use the comment box below to respond.
Posted on Aug 25, 2008
  • 1,218 Answers
Check the following information.......
http://www.fixya.com/support/t2465790-samsung_clp610nd
Posted on Sep 16, 2010
Paper Jam 0 , OPEN/Close Door Message Samsung SCX4100
seems as if the motor responsible for taking in the paper has stopped working and may need to be replaced
Dec 26, 2016 | Samsung SCX-4100 All-In-One Laser Printer
Jam 1 or No Cartridge samsung sxc-4100
make sure there is no paper stuck inside and try with replacing the toner also.
Oct 20, 2009 | Samsung SCX-4100 All-In-One Laser Printer
PAPER JAM 2,CHECK INSIDE(SCX-4521F)
paper jam 2 is your fuser sensor error,need fuser replaced.
Jul 01, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Open heat error
I think you can get a service/repair manual from this link:
http://www.nodevice.com/user_manual/samsung/printers/scx-4100.html
Jun 01, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Samsung SCX-4100 Jam 1 or no Cart
Put cartridge inside correctly and press lower inside again.
if not solved
there are loose catridge connection, check or replace cartridge (the connection at right side in the cartridge)
Feb 26, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Printer jam 2 indication
Please make sure there is no paper left (jammed) in the printer compartment.
Remove the ink cardridge and see if any piece of paper is jammed below or behind the cardridge place.
If there is a cancel button press it several times.
Switch off the printer and let it for a few minutes and then turn it on.
if nothing of the above worked please ask me again
Thank you
Aug 25, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Paper Jam 0
I have this problem too but mine is intermittent. I believe it's a physical failure of the (likely) plastic gears of the feeding system (from when I "had" to pull a dozen pages out of the jammed feeder!)
Any physical 'trauma' like that it may have experienced? You might be like me - in the market for a new printer.
Apr 01, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Lsu error pour samsung scx-4100
Please kindly help me to sole the problem Lsu of my printer samsung scx-4100
thanks
Jan 25, 2008 | Samsung ML 1610 Laser Printer
164 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
