Question about LaCie Electron III 22" CRT Monitor
Cables I've got a LaCie Electron 22 Blue II Color Display Monitor with only a powercable and I don't know what other kind / type of cables I more need to connect it to my Power Mac G3. Could one give me the exact type's of cables which I need????
Justa VGA monitor cable and a USB for th hub
Posted on Sep 23, 2008
The screen is tinted green
Check the video cable pins on both ends, also try it with another PC, or new cable.
http://s807.photobucket.com/home/budm/allalbums
Aug 13, 2010 | LaCie Electron III 22" CRT Monitor
I have a LiCie electron Blue crt monitor. I have
You have a bad connection or break in the wiring. Fix that and your monitor will work properly. Could be the wire itself or the plug you use to plug into.
Mar 05, 2017 | LaCie Electron III 22" CRT Monitor
Display went off after a sound like a cracker
sounds like a capasitor poped on the power board if the case you will need a new display the board is more expinsive sorry
Jun 29, 2009 | LaCie Electron III 22" CRT Monitor
Color settings too dark
If you can right clock on your desktop in an open area and get the graphic properties... then you should be able to do it from there.
Apr 24, 2009 | Computers & Internet
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Electron 19 blue 3 outer screen
Download this monitor test [url]http://www.iiyama.com/Download/documents/ice_pages_documents/21/MonTest_2_1.exe[/url] and click on 'convergence' Now manually change the convergence setting of your monitor with the onscreen buttons to align the red/green/blue lines
Dec 19, 2007 | LaCie Electron 19" CRT Monitor
Sounds like this one needs component-level troubleshooting in the power supply section.
Dec 31, 2006 | LaCie Electron III 22" CRT Monitor
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
Lacie Electron 22 Blue Monitor problems
This problem sounds like it has to do with your video adapter settings rather than the monitor itself. What way have happened is that your screen resolution size decreased (explaining the zoomed in), while the desktop size remained the same (explaing the ability to slide all over the place.). All video adapters are different, but try the following. Right click on your desktop and select properties. Go to the Settings tab. Do you have 2 slide bars there? Possibly one for Screen Resolution and another for Desktop size? If so, are they set to different values? Go resolve the issue, set both sliding bars to the same values, for example 1024 by 768 pixels. Adjust these setting to get back to the settings you had before, making sure that both values are the same.
Oct 03, 2006 | LaCie Electron 22" CRT Monitor
LaCie Electron III 22" CRT Monitor Logo
201 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
